主题:【分享】SDS DA系列1/2/4W输出1/2/4kVdc高压电源模块
浏览0 回复0 电梯直达
Ins_53b266b9
- Vin: 15Vdc or 24Vdc
- Vout: 0 to 1kV, 2kV or 4kV
- Pout: 1W, 2W or 4W
DA系列特别适用于控制需要高偏置电压和电流的光子探测器。工业、集成商和研究人员将受益于该装置的小尺寸、轻量化设计、出色的电压调节和减少的残余波动。
特点:
高度小,重量轻
严格的线路/负载调节
低纹波(0.005% p. to p.)
PCB平装
输出限流保护
立维创展优势代理销售SDS High Voltage高压电源模块产品
金属屏蔽,噪音低
可调从0到全输出
低纹波(< 0.003% p. to p.)
电压和电流缓冲监测
规格参数:
ParametersSpecifcations
Input voltageVin
(pins  283)
15Vdc±1.5Vdc or 24Vdc±2Vdc,according to type
Input currentExample for a 15Vdc,output 6000V,1mA model:inhibition mode:27mA
atno load &HV=1500V:46mA    at full load:260mA
HVoutputVout
(pin  8)
0 to 1000V through O to4000V according to type
PolarityFixed positive [DAP]ornegative[DAN];refer to the Selection Guide
HVsetting
(pins  4&6)
·Option 1:via externalvoltage source 0/5V±0.1%at full scale,and input
impedance=94kQ
-Option 2:via external voltage source 0/10V±0.1%at full scale,and input
impedance=187kO
Max.outputcurrent loutLimited to 110%of nominal current;referto the Selection Guide
Load voltage regulation±0,01%of full output voltagefor no loadto full load
Line voltage regulation±0,01%of full output voltage over specified input voltage range
Residual ripple0,005%peak-to-peak at full load
Temperature coefficient100ppm/℃
Output HV monitoring
(pin  7)
(still operating in inhibition
mode)
·Option 1:analog 0/+5Vbufferised output signal,accuracy±0.2%
·Option 2:analog 0/+10V bufferised output signal,accuracy±0.2%
Output impedance=1kO风
Temperature coeffcient:100ppm/℃
Output current monitoring·Option1:analog 0/+5Vbufferised output signal,accuracy±2%
(pin5)+Option2:analog 0/+10V bufferised output signal,accuracy±2%
(still operating in inhibitionOutputimpedance=1kQ
mode)Temperature coefficient:100ppm/C
HV power ON/OFFTo disable(opened remote interlock)or enable (closedremote interlock)
Operating temperatureRefer to Derating Curve
Storagetemperature-10℃to+70℃
Safeguards·Protected against reverse Vin
+Soft start feature:the start is guaranteed with no overshoot
+Auto inhibition if Tcase>75℃
+HV setting internally limited to 10.6V for the 10Vversion and to 5.3Vfor
the 5Vversion
型号:
Voutlout/PoutWinPolarityHV monitoringformer relrenceNEWHEFEHENCE
4000V1.00mA/4W  24V0/10VDA24P402102-10DA24P4-4-C10
0/5VDA24P402102-5DA24P4-4-C5
0/10VDA24N402102-10DA24N4-4-C10
0/5VDA24N402102-5DA24N4-4-C5
0.50mA/2W  24V0/10VDA24P402501-10DA24P4-2-C10
0/5VDA24P402501-5DA24P4-2-C5
0/10VDA24N402501-10DA24N4-2-C10
0/5VDA24N402501-5DA24N4-2-C5
0.25mA/1W  15V0/10VDA15P402251-10DA15P4-1-C10
0/5VDA15P402251-5DA15P4-1-C5
0/10VDA15N402251-10DA15N4-1-C10
0/5VDA15N402251-5DA15N4-1-C5
  24V0/10VDAP24402251-10DA24P4-1-C10
0/5VDAP24402251-5DA24P4-1-C5
0/10VDAN24402251-10DA24N4-1-C10
0/5VDAN24402251-10DA24N4-1-C5
2000V2.00mA/4W  15V0/10VDA15P202202-10DA15P2-4-C10
0/5VDA15P202202-5DA15P2-4-C5
0/10VDA15N202202-10DA15N2-4-C10
0/5VDA15202202-5DA15N2-4-C5
  24V0/10VDA24P202202-10DA24P2-4-C10
0/5VDA24P202202-5DA24P2-4-C5
0/10VDA24N202202-10DA24N2-4-C10
0/5VDA24N202202-5DA24N2-4-C5
1.00mA/2W  15V0/10VDA15P202102-10DA15P2-2-C10
0/5VDA15P202102-5DA15P2-2-C5
0/10VDA15N202102-10DA15N2-2-C10
0/5VDA15N202102-5DA15N2-2-C5
  24V0/10VDA24P201102-10DA24P2-2-C10
0/5VDA24P201102-5DA24P2-2-C5
0/10VDA24N201102-10DA24N2-2-C10
0/5VDA24N201102-5DA24N2-2-C5
0.50mA/IW  15V0/10VDA15P202501-10DA15P2-1-C10
0/5VDA15P202501-5DA15P2-1-C5
0/10VDA15N202501-10DA15N2-1-C10
0/5VDA15N202501-5DA15N2-1-C5
  24V0/10VDA24P202501-10DA24P2-1-C10
0/5VDA24P202501-5DA24P2-1-C5
0/10VDA24N202501-10DA24N2-1-C10
0/5VDA24N202501-5DA24N2-1-C5
1000V4.00mA/4W  15V0/10VDA15P102402-10DA15P1-4-C10
0/5VDA15P102402-5DA15P1-4-C5
0/10VDA15N102402-10DA15N1-4-C10
0/5VDA15N102402-5DA15N1-4-C5
  24V0/10VDA24P102402-10DA24P1-4-C10
0/5VDA24P102402-5DA24P1-4-C5
0/10VDA24N102402-10DA24N1-4-C10
0/5VDA24N102402-5DA24N1-4-C5
2.00mA/2W  15V0/10VDA15P102202-10DA15P1-2-C10
0/5VDA15P102202-5DA15P1-2-C5
0/10VDA15N102202-10DA15N1-2-C10
0/5VDA15N102202-5DA15N1-2-C5
  24V0/10VDA24P102202-10DA24P1-2-C10
0/5VDA24P102202-5DA24P1-2-C5
0/10VDA24N102202-10DA24N1-2-C10
0/5VDA24N102202-5DA24N1-2-C5
1mA/1W  15V0/10VDA15P102102-10DA15P1-1-C10
0/5VDA15P102102-5DA15P1-1-C5
0/10VDA15N102102-10DA15N1-1-C10
0/5VDA15N102102-5DA15N1-1-C-5
  24V0/10VDA24P102102-10DA24P1-1-C10
0/5VDA24P102102-5DA24P1-1-C5
0/10VDA24N102102-10DA24N1-1-C10
0/5VDA24N102102-5DA24N1-1-C5
