Application of COD On-line-inspecting System with UV Method in Municipal Wastewater Treatment Plant.
Abstract: The COD on-line-inspecting system with UV method has been used to analysis COD from Shunde Damen municipal wastewater treatment plant for some times. We found that the UV method has some advantages such as high speed, high accuracy and low cost. We also point out that this system has some disadvantages because of its working principle and realization of its show value source.
Key Words: COD On-line-inspecting System with UV Method;
Municipal Wastewater Treatment Plant; Water Quality
