主题:【分享】高效液相色谱法词汇
浏览0 回复5 电梯直达
樱桃小丸子
高效液相色谱法词汇
高效液相色谱法:high performance liquid chromatography,HPLC
高速液相色谱法:high speed LC,HSLC
高压液相色谱法:high pressure LC,HPLC
高分辨液相色谱法:high resolution LC,HRLC
液固吸附色谱法(液固色谱法):liquid-solid adsorption chromatography,LSC
液液色谱法:liquid-liquid chromatography,LLC
正相:normal phase,NP
反相:reversed phase,RP
化学键合相色谱法:bonded phase chromatography,BPC
十八烷基:octadecylselyl,ODS
离子对色谱法:paired ion chromatography,PIC
反相离子对色谱法:RPIC
离子抑制色谱法:ion suppression chromatography,ISC
离子色谱法:ion chromatography,IC
手性色谱法:chiral chromatography,CC
环糊精色谱法:cyclodextrin chromatography,CDC
胶束色谱法:micellar chromatography,MC
亲和色谱法:affinity chromatography,AC
固定相:stationary phase
化学键合相:chemically bonde phase
封尾、封顶、遮盖:end capping
手性固定相:chiral stationary phase,CSP
恒组成溶剂洗脱:isocraic elution
梯度洗脱:gradient elution
紫外检测器:ultraviolet detector,UVD
荧光检测器:fluorophotomeric detector,FD
电化学检测器:ECD
示差折光检测器:RID
光电二极管检测器:photodiode array detector ,DAD
三维光谱-波谱图:3D-spectrochromatogram
蒸发光散射检测器:evaporative light scattering detector,ELSD
安培检测器:ampere detector,AD
高效毛细管电泳法:high performance capillary electrophoresis,HPCE
淌度:mobility
电泳:electrophoresis
电渗:electroosmosis
动力进样:hydrodynamic injection
电动进样:electrokinetic injection
毛细管区带电泳法:capillary zone electrophoresis,CZE
胶束电动毛细管色谱:micellar electrokinetic capillary chromatography,MECC
毛细管凝胶电泳:capillary gel electrophoresis,CGE
筛分:sieving
gyhs
fccy309
hore
alittles
qingmu-1
