主题:【求助】欧洲药典中的几句翻译!
浏览0 回复11 电梯直达
caixingke
System suitablity:reference solution (b):
-resolution: minimum 3.0 between the peaks due to the α-anomer and to the β-anomer of trbenoside.
-impurity A: not more than 1.7 times the area of the corresponding peak in the chromatogram obtained with reference solution (a) (0.5 per cent ),
happyjyl
(色谱)系统适用性(试验):
对照溶液(b)(的色谱图中),三苄糖苷α-异构体和β-异构体色谱峰的分离度应大于等于3.0。
杂质A:应不超过对照溶液(a)所得色谱图中相应峰面积的1.7倍(0.5%)。
caixingke
learner1999
原文由 caixingke 发表:
-resolution:  这词具体怎么译啊?
应该是“分离度”!
sally98
happyjyl
原文由 caixingke 发表:
分离度。确定一定以及肯定。
caixingke
impurity C: not more than twice the area of the corresponding peak in the chromatogram obtained with reference solution (a) (0.5 per cent ); if the area of the peak due to impurity C in the chromatogram obtained with the test solution is greater than the area of the corresponding peak in the chromatogram obtained with reference solution (a ) (0.25 per cent ), dilute the test solution to obtain an area equal to or smaller than the area of the peak in the chromatogram obtained with reference solution (a); calculate the content of impurity C taking into account the dilution factor
caixingke
-杂质 C: 应不超过对照溶液(a)所得色谱图中相应峰面积的2倍(0.5%)。如果杂质C在测试溶液中的分离度大于在参比溶液(a )(0.25%)的中分离度,稀释测试溶液后的分离度比参比溶液(a)的峰面积小,计算杂质C的含量考虑稀释的因素。
这样译对吗?
何当奇
原文由 caixingke 发表:
这样译对吗?
(0.5%)应在(a)后面吧?
两个reference solution的翻译最好一致
何当奇
另外,peak area还是翻译为峰面积,而不应是分离度
最后依据翻译语序不对,虽然意思大家都可以明白
happyjyl
原文由 caixingke 发表:
这样译对吗?
楼主把resolution和reference solution搞混啦。reference solution是对照溶液,resolution是指所测定溶液的色谱图中,两个物质的色谱峰分离的程度。单个色谱峰是谈不上分离度的。
