It is not surprising, then, that the world saw a return to a floating exchange rate system. Central banks were no longer required to support their own currencies
Floating policy is of great importance for export trade; it is, in fact, a convenient method of insuring goods where a number of similar export transactions are intended, e.g. where the insured has to supply an overseas importer under an exclusive sales agreement or maintains sales representatives or subsidiary companies abroad.
We'd like to inform you that our counter sample will be sent to you by DHL by the end of this week and please confirm it ASAP so that we can start our mass production.
Payment will be made by 100% confirmed, irrevocable Letter of Credit available by sight draft。
注解:在第一句话中,negotiable 的意思是“可商议的”,在第二句话中的意思则是“可转让的”,“可转让提单”经过背书后即可将所有权转让给他人,值得注意的是,negotiating bank 则是议付银行,即购买或贴现汇票的银行。
例四:discount
You may get a 5% discount if your order is on a regular basis.
If a seller extends credit to a time draft, they have made a trade acceptance.The seller can request that the bank finance the transaction by buying the draft.The bank is said to discount the draft.
If a particular cargo Is partially damaged,the damage is called particular average.It's obvious that the products are below the average quality.
译文:如果某批货是部分受损,我们称之为“单独海损”。很明显,这批产品的品质是中下水平。
注解:在第一个句子中,particular average 的意思是“单独海损”,是指在保险业中由于海上事故所导致的部分损失, 因此 average 一词的意思是损失或损坏,而第二句中的 average 为“平均”之意。
例七:tender
Under CIF, it is the seller's obligation to tender the relative documents to the buyer to enable him to obtain delivery of the goods. If they arrive, or to recover for the loss, if they are lost on the voyage.
He became as exhilarated as if his tender for building a mansion had been accepted.
