原文由 jetowl 发表:
初学气质,很多不懂,用这个萃取头也是参考的文献,
Polydimethylsiloxane (PDMS) fibers,( non-polar) should be OK for the flavor components.
他那上面出来的物质蛮好的,有酸又有醛类,还有萃取头是非极性的
原文由 hiablen 发表:
个人觉得有一个原因是峰的纯度不够,可以改变下程序看看能不能分的干净一点。
原文由 jetowl 发表:
you said "Polydimethylsiloxane (PDMS) fibers,( non-polar) should be OK for the flavor components.", so you mean it's feasible for this analysis?
Secondly, I'm using Supelco 57301 as the fiber,according to the instruction, it's 100um, recommended for low molecular weight nonpolar compounds, if I use this fiber,can I get the acid or alcohol absorbed?
Sorry, Can’t not type Chinese in the office. ( asked IT guys to fix this problem, but they so lazy…American is so stupid/lazy.)
Maybe it works. Also it maybe work on the acids, alcohol, aldehydes (ketone), however, that is not a good one. But “the Supelco 57301 the fiber ( 100 um) PDMS”has better SPE affinity to the high molecular weight non-polar compounds, that maybe the reason you got so many unknown peak ( high molecular compounds).
So if your analyte is low molecular polar acid, alcohol, aldehydes (ketone), recommend the SPME fiber assembly, carbpwax-polyethyele (PEG), Supelco#57355-U, it should be good to go for the polar low molecular compounds.
Thirdly, some peak in this specture are sharp, it means the peak is single,doesn't it? If the peak isn't single, it may has several compounds, ----------- --------- -----------------------
Yes, you are right
because of this, will it make the m/z large, and the result of search comes out to be a high molecular weight compound?
No, this did not contribute any larger m/z .the GC/MSD analysis the fragment ions based on the m/z, not the retention time. 匹配因子太小,不建议采纳。<P>以上文本借助<A href="http://www.inputking.com/"
