如果你刚装个新软件,或上网浏览器出错,造成强制关机,通常会发生这种情况.
If you use 5973N or 5975, you could do something similar as follows
1. Shut down your PC.
2. On MS LUI Panel, Press "Menu" a few times, find "ChemStation"; Press "Item", Choose release ChemStation; or
Find "Controller",-> Reset controller
3. Once MS is fully restarted,check if "Chemstation is unlocked" already. If yes, restart your computer and then Chemstation.
Good luck.
原文由 cece333 发表:
Agilent GC-MS 进不了工作站了
提示为:NO response,can not bring MS online (possible bad address or existing lock)[error -204]
