原文由 lihua636 发表:
大家好,最近看了一篇英文,对于结果不是太明白,请大家帮帮忙
Fig. 3 shows the PLS loadings for the NIR calibration models
developed for DM, OMD and ADF. Clearly visible differences
between the three parameters measured were observed at spectral
regions around 1500 nm, 1900 to 2000nm and between
2100nm and 2300 nm
原文由 ruojun 发表:原文由 lihua636 发表:
2100nm and 2300 nm
表3 显示的是干物质(DM=dry matter)、干物质消化率(DMD=dry matter digestibility)和酸性洗涤纤维(ADF=acid detergent fiber)近红外(NIR)校正模型的PLS参数。在1500 nm附近, 1900 到2000nm以及 2100nm 和2300 nm间的谱区,可以观察到三个参数间明显的差异。
