继续:
Organic volatile impurities, Method V 467 : meets the requirements.
Solvent— Use dimethyl sulfoxide.
(Official until July 1, 2008)
有机挥发杂质,方法V:符合要求。溶剂:二甲亚砜。
Assay— Place about 100 mg of Stearic Acid in a small conical flask fitted with a suitable reflux attachment. Place about 50 mg of USP Stearic Acid RS and about 50 mg of USP Palmitic Acid RS in a similar flask. Treat each flask as follows. Add 5.0 mL of a solution prepared by dissolving 14 g of boron trifluoride in methanol to make 100 mL, swirl to mix, and reflux for 15 minutes or until the solid is dissolved. Cool, transfer the reaction mixture with the aid of 10 mL of chromatographic solvent hexane to a 60-mL separator, and add 10 mL of water and 10 mL of saturated sodium chloride solution. Shake, allow to separate, then drain and discard the lower, aqueous layer. Pass the hexane layer through 6 g of anhydrous sodium sulfate (previously washed with chromatographic solvent hexane) into a suitable flask. Using a syringe fitted with a suitable needle, introduce a 1-µL to 2-µL portion of the assay preparation (which contains the Stearic Acid) into a suitable gas chromatograph equipped with a flame-ionization detector. The column preferably is of glass, 1.5 m in length and 3 mm in inside diameter, and it is packed with 15% G4 on support S1A. The carrier gas is helium, passed through a bed of molecular sieve for drying, if necessary. The temperatures of the port and the detector are maintained at 210°, and the column temperature is maintained at 165°.
取硬脂酸约100mg,置于一带有回流装置的小型锥形瓶中;另取USP硬脂酸对照品与USP棕榈酸对照品各约50mg,同置于另一个带有回流装置的小型锥形瓶中。在每一个锥形瓶中,加5.0mL三氟化硼溶液(取14g三氟化硼,用甲醇溶解并稀释至100ml),搅拌使混合,回流15分钟或直至固体物溶解。放冷,将反应混合物转移至已装有10ml层析溶剂正己烷的60ml分液漏斗中,加10mL水和10mL饱和氯化钠溶液,振摇使分层,弃去下面的水层。将正己烷层用6g已用层析溶剂正己烷清洗过的无水硫酸钠过柱后放入适当的小瓶中。采用一个配备有适当针头的注射器,取1-2µL含量准备溶液(包含有硬脂酸)注入配有氢火焰离子化检测器的
气相色谱仪,柱子最好为玻璃柱,长1.5-m,内径3-mm,填料为涂有S1A的15%的G4。载气为氦气,必要时可用分子筛干燥。进样口和检测器温度均为210℃,柱温为165℃。
