Meets A.C.S. Specifications | ||
Meets Reagent Specifications for testing USP/NF monographs | ||
Appearance | Passes Test | Passes Test |
Assay (HNO3) | 69.0 - 70.0 % | 69.60% |
Arsenic (As) | 0.01 ppm max. | < 0.002 ppm |
Color (APHA) | 10 max. | 5 |
Specific Gravity at 60°/60°F | 1.416 - 1.420 | 1.418 |
Residue after Ignition | 4 ppm max. | < 2 ppm |
Trace Impurities (in ppm): | ||
Chloride (Cl) | 0.1 max. | < 0.08 |
Phosphate (PO4) | 0.2 max. | < 0.2 |
Sulfate (SO4) | 0.5 max. | < 0.2 |
Trace Impurities (in ppb): | ||
Aluminum (Al) | 100 max. | < 15 |
Arsenic and Antimony (as As) | 4 max. | < 2 |
Boron (B) | 50 max. | < 4 |
Cadmium (Cd) | Information Only | < 3 |
Calcium (Ca) | 200 max. | < 20 |
Chromium (Cr) | 100 max. | < 8 |
Copper (Cu) | 50 max. | < 2 |
Gold (Au) | 200 max. | < 3 |
Heavy Metals (as Pb) | 100 max. | < 50 |
Iron (Fe) | 100 max. | < 40 |
Lead (Pb) | 100 max. | < 4 |
Magnesium (Mg) | 100 max. | < 20 |
Manganese (Mn) | 100 max. | < 4 |
Mercury (Hg) | 5 max. | < 1 |
Nickel (Ni) | 50 max. | < 3 |
Potassium (K) | 300 max. | < 20 |
Tin (Sn) | 200 max. | < 4 |
Titanium (Ti) | 200 max. | < 15 |
Zinc (Zn) | 200 max. | < 20 |
For Laboratory, Research or Manufacturing Use | ||
