1. Oven Temperature Program (GC)— Adjustment of temperatures is permitted as stated above.
2. For the times specified for the temperature to be maintained or for the temperature to be changed from one value to another, an adjustment of up to ±20% is permitted.
3. Unless otherwise directed in the monograph, system suitability parameters are determined from the analyte peak.
