另外还有~
ASTM C 24-2001
耐火和高矾土耐溶材料的溶锥当量标准试验方法
Standard Test Method for Pyrometric Cone Equivalent (PCE) of Fireclay and High Alumina Refractory Materials
ASTM C 27-1998
耐火土及高矾土耐火砖的标准分类
Standard Classification of Fireclay and High-Alumina Refractory Brick
ASTM C 673-1997
耐火粘土及高矾土的塑性耐火材料及捣实混合物的标准分类
Standard Classification of Fireclay and High-Alumina Plastic
Refractories and Ramming Mixes
ASTM C 690-2003
用电感应区域法测定矾土或石英粒度分布的标准试验方法
Standard Test Method for Particle Size Distribution of Alumina or Quartz by Electric Sensing Zone Technique
ASTM C 958-1992
用重力沉积的X射线监测器测定矾土或石英的粒度分布的试验方法
Test Method for Particle Size Distribution of Alumina or Quartz by X-Ray Monitoring of Gravity Sedimentation
ASTM C 1182-1991
用离心测光沉淀法测定矾土的粒径分布用标准试验方法
Standard Test Method for Determining the Particle Size Distribution of Alumina by Centrifugal Photosedimentation
ASTM D 2442-1975
电气和电子设备用矾土陶瓷
Alumina Ceramics for Electrical and Electronic Applications
ASTM D 4926-2006
用X-射线粉末衍射法对触煤剂中含硅和铝矾土的触煤剂中伽马铝矾土含量的试验方法
Standard Test Method for Gamma Alumina Content in Catalysts Containing Silica and Alumina by X-ray Powder Diffraction
NF B49-421-1990
耐火材料制品.铝矾土、硅质材料、碳化硅、碳和金属硅耐火材料制品的化学分析
Refractory products. Chemical analysis of aluminous, siliceous, silicon carbide, carbon and metallic silicon refractory products.
NF B49-431-1995
耐火制品的化学分析.第2部分:含硅石和/或矾土制品(湿法)
Chemical analysis of refractory products. Part 2 : products containing silica and/or alumina (wet method).
