进样瓶有其他的瓶子可以代替,比如说 Advanced Quality AQ™ autosampler vials,玻璃瓶内壁经过钝化处理,溶液的pH不会发生变化,也不会产生吸附。
9509S-WCV-RS Vials, AQ brand, 9-425mm screw top, 2ml clear with write on patch, RSA Glass 12x32mm, in clear packaging. 100/pack.
http://www.microsolvtech.com/PDF/RSA_Brochure.pdf
