主题:化学元素英汉对照及化学常用词汇汉英对照表
浏览0 回复7 电梯直达
一抹冰蓝
该帖子已被happyjyl设置为精华;
Actinium(Ac) 锕
    Aluminium(Al) 铝
    Americium(Am) 镅
    Antimony(Sb) 锑
    Argon(Ar) 氩
    Arsenic(As) 砷
    Astatine(At) 砹
    Barium(Ba) 钡
    Berkelium(Bk) 锫
    Beryllium(Be) 铍
    Bismuth(Bi) 铋
    Boron(B) 硼
    Bromine(Br) 溴
    Cadmium(Cd) 镉
    Caesium(Cs) 铯
    Calcium(Ca) 钙
    Californium(Cf) 锎
    Carbon(C) 碳
    Cerium(Ce) 铈
    Chlorine(Cl) 氯
    Chromium(Cr) 铬
    Cobalt(Co) 钴
    Copper(Cu) 铜
    Curium(Cm) 锔
    Dysprosium(Dy) 镝
    Einsteinium(Es) 锿
    Erbium(Er) 铒
    Europium(Eu) 铕
    Fermium(Fm) 镄
    Fluorine(F) 氟
    Francium(Fr) 钫
    Gadolinium(Gd) 钆
    Gallium(Ga) 镓
    Germanium(Ge) 锗
    Gold(Au) 金
    Hafnium(Hf) 铪
    Helium(He) 氦
    Holmium(Ho) 钬
    Hydrogen(H) 氢
    Indium(In) 铟
    Iodine(I) 碘
    Iridium(Ir) 铱
    Iron(Fe) 铁
    Krypton(Kr) 氪
    Lanthanum(La) 镧
    Lawrencium(Lr) 铹
    Lead(Pb) 铅
    Lithium(Li) 锂
    Lutetium(Lu) 镥
    Magnesium(Mg) 镁
    Manganese(Mn) 锰
    Mendelevium(Md) 钔 Mercury(Hg) 汞
    Molybdenum(Mo) 钼
    Neodymium(Nd) 钕
    Neon(Ne) 氖
    Neptunium(Np) 镎
    Nickel(Ni) 镍
    Niobium(Nb) 铌
    Nitrogen(N) 氮
    Nobelium(No) 锘
    Osmium(Os) 锇
    Oxygen(O) 氧
    Palladium(Pd) 钯
    Phosphorus(P) 磷
    Platinum(Pt) 铂
    Plutonium(Pu) 钚
    Polonium(Po) 钋
    Potassium(K) 钾
    Praseodymium(Pr) 镨
    Promethium(Pm) 钷
    Protactinium(Pa) 镤
    Radium(Ra) 镭
    Radon(Rn) 氡
    Rhenium(Re) 铼
    Rhodium(Rh) 铑
    Rubidium(Rb) 铷
    Ruthenium(Ru) 钌
    Samarium(Sm) 钐
    Scandium(Sc) 钪
    Selenium(Se) 硒
    Silicon(Si) 硅
    Silver(Ag) 银
    Sodium(Na) 钠
    Strontium(Sr) 锶
    Sulphur(S) 锍
    Tantalum(Ta) 钽
    Technetium(Tc) 锝
    Tellurium(Te) 碲
    Terbium(Tb) 铽
    Thallium(Tl) 铊
    Thorium(Th) 钍
    Tin(Sn) 锡
    Thulium(Tm) 铥
    Titanium(Ti) 钛
    Tungsten(W) 钨
    Uranium(U) 铀
    Vanadium(V) 钒
    Xenon(Xe) 氙
    Ytterbium(Yb) 镱
    Yttrium(Y) 钇
    Zinc(Zn) 锌
    Zirconium(Zr) 锆
一抹冰蓝
●化学常用词汇汉英对照表1●
    氨    ammonia
    氨基酸    amino acid
    铵盐    ammonium salt
    饱和链烃    saturated aliphatic hydrocarbon
    苯    benzene
    变性    denaturation
    不饱和烃    unsaturated hydrocarbon
    超导材料    superconductive material
    臭氧    ozone
    醇    alcohol
    次氯酸钾    potassium hypochlorite
    醋酸钠    sodium acetate
    蛋白质    protein
    氮族元素    nitrogen group element
    碘化钾    potassium iodide
    碘化钠    sodium iodide
    电化学腐蚀    electrochemical corrosion
    电解质    electrolyte
    电离平衡    ionization equilibrium
    电子云    electron cloud
    淀粉    starch
    淀粉碘化钾试纸    starch potassium iodide paper
    二氧化氮    nitrogen dioxide
    二氧化硅    silicon dioxide
    二氧化硫    sulphur dioxide
    二氧化锰    manganese dioxide
    芳香烃    arene
    放热反应    exothermic reaction
    非极性分子    non-polar molecule
    非极性键    non-polar bond
    肥皂    soap
    分馏    fractional distillation
    酚    phenol
    复合材料    composite
    干电池    dry cell
    干馏    dry distillation
    甘油    glycerol
    高分子化合物    polymer
    共价键    covalent bond
    官能团    functional group
    光化学烟雾    photochemical fog
    过氧化氢    hydrogen peroxide
    合成材料    synthetic material
    合成纤维    synthetic fiber
    合成橡胶    synthetic rubber
    核电荷数    nuclear charge number
    核素    nuclide
    化学电源    chemical power source
    化学反应速率    chemical reaction rate
    化学键    chemical bond
    化学平衡    chemical equilibrium
    还原剂    reducing agent
    磺化反应    sulfonation reaction
    霍尔槽 Hull Cell
    极性分子    polar molecule
    极性键    polar bond
    加成反应    addition reaction
    加聚反应    addition polymerization
    甲烷    methane
    碱金属    alkali metal
    碱石灰    soda lime
    结构式    structural formula
    聚合反应    po1ymerization
    可逆反应    reversible reaction
    空气污染指数    air pollution index
    勒夏特列原理    Le Chatelier's principle
    离子反应    ionic reaction
    离子方程式    ionic equation
    离子键    ionic bond
    锂电池    lithium cell
    两性氢氧化物    amphoteric hydroxide
    两性氧化物    amphoteric oxide
    裂化    cracking
    裂解    pyrolysis
    硫氰化钾    potassium thiocyanate
    硫酸钠    sodium sulphide
    氯化铵    ammonium chloride
    氯化钡    barium chloride
    氯化钾    potassium chloride
    氯化铝    aluminium chloride
    氯化镁    magnesium chloride
    氯化氢    hydrogen chloride
    氯化铁    iron (III) chloride
    氯水    chlorine water
    麦芽糖    maltose
    煤    coal
    酶    enzyme
    摩尔    mole
    摩尔质量    molar mass
    品红    magenta或fuchsine
    葡萄糖    glucose
    气体摩尔体积    molar volume of gas
    铅蓄电池    lead storage battery
    强电解质    strong electrolyte
    氢氟酸    hydrogen chloride
    氢氧化铝    aluminium hydroxide
    取代反应    substitution reaction
    醛    aldehyde
    炔烃    alkyne
    燃料电池    fuel cell
    弱电解质    weak electrolyte
    石油    Petroleum
    水解反应    hydrolysis reaction
    四氯化碳    carbon tetrachloride
    塑料    plastic
    塑料的降解    plastic degradation
    塑料的老化    plastic ageing
    酸碱中和滴定    acid-base neutralization titration
    酸雨    acid rain
    羧酸    carboxylic acid
    碳酸钠 sodium carbonate
    碳酸氢铵 ammonium bicarbonate
    碳酸氢钠 sodium bicarbonate
    糖类 carbohydrate
    烃 hydrocarbon
    烃的衍生物 derivative of hydrocarbon
    烃基 hydrocarbonyl
    同分异构体 isomer
    同素异形体 allotrope
    同位素 isotope
    同系物 homo1og
    涂料 coating
    烷烃 alkane
    物质的量 amount of substance
    物质的量浓度 amount-of-substance concentration of B
    烯烃 alkene
    洗涤剂 detergent
    纤维素 cellulose
一抹冰蓝
相对分子质量 relative molecular mass
    相对原子质量 relative atomic mass
    消去反应 elimination reaction
    硝化反应 nitratlon reaction
    硝酸钡 barium nitrate
    硝酸银    silver nitrate
    溴的四氯化碳溶液 solution of bromine in carbon tetrachloride
    溴化钠 sodium bromide
    溴水    bromine water
    溴水 bromine water
    盐类的水解 hydrolysis of salts
    盐析    salting-out
    焰色反应 flame test
    氧化剂    oxidizing agent
    氧化铝 aluminium oxide
    氧化铁 iron (III) oxide
    乙醇    ethanol
    乙醛 ethana1
    乙炔 ethyne
    乙酸    ethanoic acid
    乙酸乙酯 ethyl acetate
    乙烯    ethene
    银镜反应    silver mirror reaction
    硬脂酸    stearic acid
    油脂 oils and fats
    有机化合物 organic compound
    元素周期表 periodic table of elements
    元素周期律 periodic law of elements
    原电池 primary battery
    原子序数 atomic number
    皂化反应 saponification
    粘合剂 adhesive
    蔗糖 sucrose
    指示剂 Indicator
    酯 ester
    酯化反应 esterification
    周期    period
    族    group(主族:main group)
    Bunsen burner 本生灯
    product 化学反应产物
    flask 烧瓶
    apparatus 设备
    PH indicator PH值指示剂,氢离子(浓度的)负指数指示剂
    matrass 卵形瓶
    litmus 石蕊
    litmus paper 石蕊试纸
    graduate, graduated flask 量筒,量杯
    reagent 试剂
    test tube 试管
    burette 滴定管
    retort 曲颈甑
    still 蒸馏釜
    cupel 烤钵
    crucible pot, melting pot 坩埚
    pipette 吸液管
    filter 滤管
    stirring rod 搅拌棒
    element 元素
    body 物体
    compound 化合物
    atom 原子
    gram atom 克原子
    atomic weight 原子量
    atomic number 原子数
    atomic mass 原子质量
    molecule 分子
    electrolyte 电解质
    ion 离子
    anion 阴离子
    cation 阳离子
    electron 电子
    isotope 同位素
    isomer 同分异物现象
    polymer 聚合物
    symbol 复合
    radical 基
    structural formula 分子式
    valence, valency 价
    monovalent 单价
    bivalent 二价
    halogen 成盐元素
    bond 原子的聚合
    mixture 混合
    combination 合成作用
    compound 合成物
    alloy 合金
    organic chemistry 有机化学
    inorganic chemistry 无机化学
    derivative 衍生物
    series 系列
    acid 酸
    hydrochloric acid 盐酸
    sulphuric acid 硫酸
    nitric acid 硝酸
    aqua fortis 王水
    fatty acid 脂肪酸
    organic acid 有机酸 hydrosulphuric acid 氢硫酸
    hydrogen sulfide 氢化硫
    alkali 碱,强碱
    ammonia 氨
    base 碱
    hydrate 水合物
    hydroxide 氢氧化物,羟化物
    hydracid 氢酸
    hydrocarbon 碳氢化合物,羟
    anhydride 酐
    alkaloid 生物碱
    aldehyde 醛
    oxide 氧化物
    phosphate 磷酸盐
    acetate 醋酸盐
    methane 甲烷,沼气
    butane 丁烷
    salt 盐
    potassium carbonate 碳酸钾
    soda 苏打
    sodium carbonate 碳酸钠
    caustic potash 苛性钾
    caustic soda 苛性钠
    ester 酯
    gel 凝胶体
    analysis 分解
    fractionation 分馏
    endothermic reaction 吸热反应
    exothermic reaction 放热反应
    precipitation 沉淀
    to precipitate 沉淀
    to distil, to distill 蒸馏
    distillation 蒸馏
    to calcine 煅烧
    to oxidize 氧化
    alkalinization 碱化
    to oxygenate, to oxidize 脱氧,氧化
    to neutralize 中和
    to hydrogenate 氢化
    to hydrate 水合,水化
    to dehydrate 脱水
    fermentation 发酵
    solution 溶解
    combustion 燃烧
    fusion, melting 熔解
    alkalinity 碱性
    isomerism, isomery 同分异物现象
    hydrolysis 水解
    electrolysis 电解
    electrode 电极
    anode 阳极,正极
    cathode 阴极,负极
    catalyst 催化剂
    catalysis 催化作用
    oxidization, oxidation 氧化
    reducer 还原剂
    dissolution 分解
    synthesis 合成
    reversible 可逆的
niupi
l0507
jiangjj107
jacksteel
ycy-79
