主题:【原创】Do you know what is plasticizer? Do you know something or background on plasticizer? sign up 26 June
浏览0 回复15 电梯直达
symmacros
Do you know what  is plasticizer? Do you know something or background on plasticizer? Do test It?
该帖子作者被版主 天晴了10积分, 2经验,加分理由:first sign
hxf119
symmacros
原文由 hxf119(hxf119) 发表:
Yes, I know plasticizer, I always use it
Why do you use it?
yuduoling
symmacros
原文由 yuduoling(yuduoling) 发表:
This is a question needs you answer.
无名
For soften or other fields needs plasticity, then plasticizer will be exist.
影子
Something that makes plastics less rigid, by breaking up the molecules. Plasticizers give plastic flexibility and durability.
dahua1981
qlmkk
Sorry,I do not know what  is plasticizer.what  is the  plasticizer?
小M
I guess it's 塑化剂 for its spelling. I don't use the plasticizer.
symmacros
原文由 小M(mitchell_dyzy) 发表:
Yes, plasticizer is  塑化剂.
