原文由 liumancang(v2912500) 发表:峰面积归一法本来就是大概的。。
我也是用这种半定量方法做的植物挥发物,审稿人提出了如下问题,如下:
Can you explain your quantification further? If you compared a volatiles peak area to that of a dose response curve of a known amount of the standard of that specific compound then this is fine. But if you just looked at ratios to a single internal standard then I do not believe this is appropriate as the MS will have different sensitivity to different compounds. If the later then it is better to report peak area than quantities that will not be accurate.
该如何回复?
原文由 liumancang(v2912500) 发表:没有标样,要比较准确的定量就难了。请问是测定单个样品呢?还是比较几个样品呢?
该如何回复?
