主题:【讨论】what will you do after you fell wronged?
浏览0 回复6 电梯直达
xiaohongmaode
hello everybody:
          if you were always working hard,practivly sloved problem and found solutions.one day ,you wanted  to decrease the cost from    phosphating.and then you had some problem.so ,the leader just said some words.the OP wanted to call your names because the experiment  affecting prodution.
          is it wrong? do you fell wronged?what will you do?
symmacros
上海卓技
dahua1981
xiaohongmaode
天天洗碗
at first maybe feel bad,but I will  solve the problem as soon as  possible。
xiaohongmaode
enn,thanks ,i know what should i do.actually the mould was damaged by the samples which were producted in my way.so it's normal that they hate me.but ,i know the limited at least.so i think it was worth.i will make it to the end!thanks everybody.
