BS 476 Fire tests on building materials and structures 建筑材料和构件的燃烧试验
BS 476-3:2004 Fire tests on building materials and structures. Classification and method of test for external fire exposure to roofs
Cross references: BS EN 13238, BS EN 13501-1
BS 476-4:1970 Fire tests on building materials and structures. Non-combustibility test for materials 材料的不可燃性试验
Cross references: BS 2782:Part 5/508, BS 3763, BS 4422, PD 5686
BS 476-6:1989 Fire tests on building materials and structures. Method of test for fire propagation for products 制品火势蔓延的试验方法
Cross references: BS 476:Part 10, BS 476:Part 13, BS 4422:Part 1, BS 4422:Part 2, BS 4422:Part 5, BS 4947, PD 6498, Health and Safety at Work etc. Act 1974, Asbestos Regulations 1969
BS 476-7:1997 Fire tests on building materials and structures. Method of test to determine the classification of the surface spread of flame of products 制品表面火势蔓延的试验和分级方法
Cross references BS 476:Part 10, BS 4422:Part 1, BS 4422:Part 2, BS 4422:Part 5, BS 6809
BS 476-10:1983 Fire tests on building materials and structures. Guide to the principles and application of fire testing
Cross references BS 476:Part 3, BS 476:Part 7, BS 476:Part 8, BS 476:Part 12, BS 476:Part 13, BS 476:Part 14, BS 476:Part 15, BS 476:Part 16, BS 476:Part 20, BS 476:Part 21, BS 476:Part 22, BS 476:Part 23, BS 476:Part 24, BS 476:Part 30, BS 4422:Part 1, BS 4422:Part 2,
BS 476-11:1982 Fire tests on building materials and structures. Method for assessing the heat emission from building materials 建筑材料热辐射的评定方法
Cross references: BS 476:Part 10, PD 6508, ISO 1182, Asbestos Regulations 1969, Health and Safety at Work etc. Act 1974
BS 476-12:1991 Fire tests on building materials and structures. Method of test for ignitability of products by direct flame impingement
Cross references: BS 415, BS 476:Part 6, BS 3016, BS 3212, BS 4250:Part 1, BS 5423, BS 5852, BS 6458:Section 2.2, BS 6575, Health and Safety at Work etc. Act 1974
BS 476-13:1987 Fire tests on building materials and structures. Method of measuring the ignitability of products subjected to thermal irradiance
Cross references: BS 2782:Part 10:Method 1004, BS 4422, BS 5497:Part 1, ISO/TR 3814, ISO/TR 6585
BS 476-15:1993 Fire tests on building materials and structures. Method for measuring the rate of heat release of products
Cross references: ISO 554, ISO/TR 3814, ISO/IEC Guide 52, BS 6809, ISO 5657, ISO 5725, ASTM E 1354
BS 476-20:1987 Fire tests on building materials and structures. Method for determination of the fire resistance of elements of construction (general principles) 建筑构件耐火的测定方法(一般原理)
Cross references: BS 476:Part 21, BS 476:Part 22, BS 476:Part 23, BS 476:Part 24, BS 4422, BS 4937:Part 4, BS 4937:Part 5, PD 6496, ISO 3008, ISO 3009, EUR 8750, Health and Safety at Work etc. Act 1974, Asbestos Regulations 1969
BS 476-21:1987 Fire tests on building materials and structures. Methods for determination of the fire resistance of loadbearing elements of construction
Cross references: BS 476:Part 20, BS 476:Part 22, BS 476:Part 23, BS 4422, Health and Safety at Work etc. Act 1974, Asbestos Regulations 1969
BS 476-22:1987 Fire tests on building materials and structures. Methods for determination of the fire resistance of non-loadbearing elements of construction
Cross references: BS 476:Part 4, BS 476:Part 6, BS 476:Part 7, BS 476:Part 20, BS 476:Part 21, BS 476:Part 23, BS 476:Part 24, BS 476:Section 31.1, BS 4422, BS 6262, ISO 834, ISO 3008, ISO 3009, Health and Safety at Work etc. Act 1974, Asbestos Regulations 1969
BS 476 Part 23: 1987 Methods for the determination of the contribution of components to the fire resistance of a structure.
BS 476 Part 24: 1987, ISO 6944 : 1985 Method for the determination of the fire resistance of ventilation ducts.
BS 476 Part 31.1: 1983 Methods for measuring smoke penetration through doorsets and shutter assemblies. Method of measurement under ambient temperature conditions.
BS 476 Part 32: 1989 Guide to full scale fire tests within buildings.
BS 476 Part 33: 1993, ISO 9705 : 1993 Full-scale room test for surface products
