【作者】 李锐;
【Author】 Li Rui (Nanning Institute for Food and Drug Control,Nanning,Guangxi,China 530001)
【机构】 广西壮族自治区南宁食品药品检验所 广西 南宁 530001;
【摘要】 目的采用高效
液相色谱法(HPLC法)测定曲匹布通片的含量。方法色谱柱为Diamonsil(TM)C18柱(250 mm×4.6 mm,5μm),流动相为pH=3.3的乙腈-0.01 mol/L磷酸二氢钾溶液(60:40),流速为1 mL/min,检测波长为235 nm,柱温为35℃。结果曲匹布通质量浓度在4~20μg/mL范围内与峰面积线性关系良好(r=0.999 9),平均加样回收率为100.50%,RSD为0,40%(n=6)。结论HPLC法简便、快速,结果准确、可靠,重现性好,可用于曲匹布通片的含量测定。 更多还原
【Abstract】 Objective To establish a method for the content determination of trepibutone tablets by HPLC.Methods Diamonsil (TM) C18 column (250mm×4.6 mm,5μm) was adopted.The mobile phase was a mixture of pH=3.3 acetonitrile-0.01 mol/L potassium dihydrogen phosphate (60:40) and the flow rate was 1 mL/min.The detection wavelength was 235 nm.The temperature was set at 35℃.Results The calibration curve was good linear relationship in the range of 4-20μg/mL (r=0.999 9).The mean recovery rate was 100.5... 更多还原
【关键词】 高效
液相色谱法; 曲匹布通; 含量测定;
【Key words】 HPLC; trepibutone; content determination;
