http://www.pcimag.com/articles/dsc-technology-an-enhanced-tool-for-coatings-analysis
里面有一段话“Since the exothermic energy is a direct measure of the bonds formed, measuring the peak area (energy units) can be used to assess additional bond formation. Measuring the residual curing energy and comparing it to a theoretical or standard value provides a measure of the degree of cure. The Tg can also be used to estimate degree of cure if a correlation has previously been established.”可能指的与楼主所说有关。
