主题:【讨论】IEC62321:2013 剩余的几个部分预计什么时候颁布呢
浏览0 回复18 电梯直达
ian.cheng
去年公布的料1-5个部分,还有6-8三个部分尚没公布,大家是否有这方面的消息呢?
大概什么时候会颁布呢
loaferfdu
IEC官方网站有的,搜一下就看到了。
2014-07 IEC 62321-6 Ed. 1.0     Determination of certain substances in electrotechnical products - Part 6: Determination of polybrominated biphenyls and polybrominated diphenyl ethers in polymers and electronics by gc-MS, IAMS and HPLC-UV
2015-02  IEC 62321-7-1 Ed. 1.0    Determination of certain substances in electrotechnical products - Part 7-1: Determination of the presence of hexavalent chromium (Cr(VI)) in colourless and coloured corrosion-protected coatings on metals by the colorimetric method
2015-07    IEC 62321-7-2 Ed. 1.0    Determination of certain substances in electrotechnical products - Part 7-2: Determination of hexavalent chromium (Cr(VI)) in polymers and electronics by the colorimetric method
2015-06  IEC 62321-8 Ed. 1.0  Determination of certain substances in electrotechnical products - Part 8: Determination of specific phthalates in polymer materials by mass spectrometry
该帖子作者被版主 chengxiaojun2积分, 2经验,加分理由:参与讨论
ian.cheng
luohi123
第六部分这个月应出来了吧,期待有人共享下。
ian.cheng
原文由 luohi123(luohi123) 发表:
嗯,是的,又的话还是会分享下的,不过应该没这么快
harriet
第六部也要到2015年才出了。下面是IEC给我回复邮件说的.
Dear ,
Thank you for your patience.
According to the responsible TC the standard IEC 62321-6 ed. 1.0 is expected to be published in April 2015.
If you have any questions please do not hesitate to contact us.
Best regards,
Karlheinz Ulmer
Customer Service Representative
IEC – International Electrotechnical Commission | Rue de Varembé 3 | P.O. Box 131 | CH–1211 Geneva 20 | Switzerland | tel: +41 22 919 0211 | website
ian.cheng
原文由 harriet(wrj318) 发表:
Dear ,
Best regards,
Karlheinz Ulmer
直接与官方联系,也是不错的一个方法。
luohi123
原来第六部分要明年四月才出来啊,又推后了。明年要提交复评审,估计还得重新做方法确认工作。
ian.cheng
嗯,这个每次更新后,内部实验室方法是不是都要重新确认验证呢
luohi123
原文由 ian.cheng(chengxiaojun) 发表:
做下标准变更评估吧,如果测试过程和测试参数没变化就不需要重新再做方法确认工作了。
merrylei
