原文由 Tinker(v2910012) 发表:原文由 popcorn(yanghua5530) 发表:
如果样品的结果总是被稀释成小于最高校准曲线标准点就不需要做线性。
不是很明白,高手指教
原文由 popcorn(yanghua5530) 发表:原文由 Tinker(v2910012) 发表:原文由 popcorn(yanghua5530) 发表:
不是很明白,高手指教
根据GLOP 7409,如果日常测试时,样品溶液总是稀释到浓度低于标准溶液最高点的浓度,则可不做线性测试(Linearity)。见Mattel GLOP 7409原文:
2.5.4 Linearity
2.5.4.2 Linearity does not need to be performed if the sample result is always to be diluted below the highest calibration standard. For example, a sample result of 50 ppm will be diluted 10 fold to obtain a result of approximately 5 ppm which is below the highest calibration standard of 10 ppm.
