主题:【求文献】三篇 Electrophoresis 杂志97-98年的文献
浏览0 回复13 电梯直达
芝兰
该帖子已被luqinhua设置为精华;
(1) G. Rippel, H. Corstjens, H.A.H. Billiet, J. Frank, Affinity capillary electrophoresis, Electrophoresis 18 (1997) 2175–2183.
(2) I.J. Colton, J.D. Carbeck, J. Rao, G.M. Whitesides, Affinity capillary electrophoresis: A physical-organic tool for studying interactions in biomolecular recognition, Electrophoresis 19 (1998) 367–382
(3) K.L. Rundlett, D.W. Armstrong, Methods for the estimation of
binding constants by capillary electrophoresis, Electrophoresis 18
(1997) 2194–2202
wds408
独角兽
搜了一下也没找到,我想学校的文献系统中应该能检索到吧,现在在外面和上学的时候可没办法比了。
wanghf0821
对不起,pdf无法下载,只能看到摘要。不知有用否?Electrophoresis,1998,19,367-382
Review
Ian J. Colton, Jeffrey D. Carbeck, Jianghong Rao, Professor George M. Whitesides *
Department of Chemistry and Chemical Biology, Harvard University, Cambridge, MA, USA
email: George M. Whitesides (gwhitesides@gmwgroup.harvard.edu)
*Correspondence to George M. Whitesides, Department of Chemistry and Chemical Biology, Harvard University, Cambridge, MA 02138, USA (Tel: +617-495-9431; Fax: +617-495-9857)
Keywords
Affinity capillary electrophoresis ?Binding affinity ?Scatchard analysis ?Dissociation constant
Abstract
Affinity capillary electrophoresis (ACE) is a technique that is used to measure the binding affinity of receptors to neutral and charged ligands. ACE experiments are based on differences in the values of electrophoretic mobility of free and bound receptor. Scatchard analysis of the fraction of bound receptor, at equilibrium, as a function of the concentration of free ligand yields the dissociation constant of the receptor-ligand complex. ACE experiments are most conveniently performed on fused silica capillaries using a negatively charged receptor (molecular mass < 50 kDa) and increasing concentrations of a low molecular weight, charged ligand in the running buffer. ACE experiments that involve high molecular weight receptors may require the use of running buffers containing zwitterionic additives to prevent the receptors from adsorbing appreciably to the wall of the capillary. This review emphasizes ACE experiments performed with two model systems: bovine carbonic anhydrase II (BCA II) with arylsulfonamide ligands and vancomycin (Van), a glycopeptide antibiotic, with D-Ala-D-Ala (DADA)-based peptidyl ligands. Dissociation constants determined from ACE experiments performed with charged receptors and ligands can often be rationalized using electrostatic arguments. The combination of differently charged derivatives of proteins - protein charge ladders - and ACE is a physical-organic tool that is used to investigate electrostatic effects. Variations of ACE experiments have been used to estimate the charge of Van and of proteins in solution, and to determine the effect of the association of Van to Ac2KDADA on the value of pKa of its N-terminal amino group.
wanghf0821
Electrophoresis,1997,18,2175-2183
实在不行的话,可给作者发E-mail要原文。
Review
Geza Rippel, Hugo Corstjens, Hugo A. H. Billiet, Dr. Johannes Frank *
Delft University of Technology, Kluyver Laboratory of Biotechnology, Department of Biochemical Engineering, Delft, The Netherlands
email: Johannes Frank (frank@stm.tudelft.nl)
*Correspondence to Johannes Frank, Delft University of Technology, Kluyver Laboratory of Biotechnology, Department of Biochemical Engineering, Julianalaan 67, NL-2628 BC Delft, The Netherlands (Tel: +31-15-278-2332; Fax: +31-15-278-2355)
Keywords
Binding constant ?Affinity capillary electrophoresis ?Molecular interaction
Abstract
The application of affinity capillary electrophoresis (ACE) to the study of molecular interactions is reviewed. ACE appears to be a sensitive, versatile and convenient tool to obtain reliable data on binding constants and stoichiometries of interacting systems using the Hummel-Dreyer method and variants thereof. A powerful feature is the possibility to analyze simultaneously the affinity of a large number of compounds for the same ligand, making it a promising tool for the screening of large combinatorial libraries.
Received: 12 June 1997
wanghf0821
Electrophoresis,1997,18,2194-2202
这三篇全是综述。斑竹要写东西吗?
Review
Methods for the estimation of binding constants by capillary electrophoresis
Kimber L. Rundlett, Professor Daniel W. Armstrong *
Department of Chemistry, University of Missouri-Rolla, Rolla, MO, USA
email: Daniel W. Armstrong (mrichard@umr.edu)
*Correspondence to Daniel W. Armstrong, Department of Chemistry, University of Missouri-Rolla, Rolla, MO 65401, USA (Tel: +573-341-4429; Fax: +573-341-6166)
Keywords
Equilibrium constants ?Molecular association ?Linear plotting ?Nonlinear regression ?Errors
Abstract
Capillary electrophoresis (CE) has developed into a particularly effective means to determine apparent equilibrium constants for molecular association in solution (e.g., to micelles, cyclodextrins, antibiotics, proteins, RNA, DNA. etc.). The various experimental, graphical and mathematical approaches for determining association constants are reviewed. In CE, association constants can be calculated because there is a relationship between substrate concentration and the measured electrophoretic mobility of the solute. Most of the approaches for obtaining association constants by CE are conceptually and mathematically related to one another. Likewise, they are analogous to many spectroscopic techniques that are used for obtaining association constants. The advantages, limitations and proper use of the various CE approaches are examined.
Received: 18 July 1997
wds408
芝兰
不好意思,是wds408要这三篇文献,那天他发E-mail给我,请我帮他找这三篇文献,我没找到,所以发到版上求助了。
非常感谢zhl2005,wanghf0821的热心相助。
wds408
问楼上
e-mail 正确吗?
前面是什么东西
是人名
也是mail 里面的东西吗?
wds408
问楼上
e-mail 正确吗?
前面是什么东西
是人名
也是mail 里面的东西吗?
wanghf0821
前面应该是人名,括号里的是E-mail. 我们学校98年以前的看不到全文。不过毕竟八九年了,如果不对,你可以上网查找他们现在的E-mail.
