Place, in a beaker, a sufficient volume of the food simulant to fill the three test specimens to the nominal volume, if known, or to 5 mm from the top and to provide two 200 ml blanks
Pace, in a beaker, a sufficient volume of the food simulant to fill the three test specimens to the nominal volume, if known, or to 5 mm from the top and to provide two 200 ml blanks
原文由 zhengchao5211 发表: Place, in a beaker, a sufficient volume of the food simulant to fill the three test specimens to the nominal volume, if known, or to 5 mm from the top and to provide two 200 ml blanks
