我的理解是这样的:这段话的关键是这一句However, the results as a whole confirm the low pH-dependence of the Aquacoat film. The dissolution rate appears to be more dependent on the nature of the medium than on its pH value. “然而,把结果作为一个整体来看待的话,可以看出药物的溶出度是Aquacoat film低PH依赖型的,溶出速率更多的依赖于介质本身的属性,而不是介质的PH值! 因此楼主的这句话我认为应该翻译成:在不同的PH中,最慢的溶出度与最快的溶出度虽然有所不同,但仅差7个百分点! 见笑,第一次在这翻译,不知道对不对?
However, the profiled obtained with the pH 4.5, 6.9 and 7.2 media are similar, and the difference between the slowest and fastest profiles is 7 points.
