原文由 littlewing 发表:
这个地方的phase当如ruojun所说,翻译成“阶段”,原文第三页也有说明
The software is designed to
incorporate two phases of the chromatographic analysis, the
dynamic injection phase and the static elution phase. During the
dynamic phase, the switching of the injection valve will create
rather sudden and direct changes in primarily the pressure sensor
outputs.
这个就表明dynamic injection phase中 phase就是阶段吗?
Figure 4 The Hotelling T-square graph shows the T2 value for each sample in the dynamic injection phase after the first 3 principal components
figure 6 The Hotelling T-square graph shows the T2 value for each sample in the static elution phase
都表明了这个应该是是指流动相和固定相吧?
还是对
液相了解的不深
