个人认为翻译时最好能将中文通顺一下,以便理解.
An idle client is one which has transmitted no keyboard or pointer events for more than a certain length of time. The K4000RC Server can be configured with a threshold, expressed in seconds, after which idle clients will be disconnected to conserve resources.
一个空闲的客户端程序是指超过一定时长的没有键盘输入或指示器输入(触摸屏之类的功能)事件。K4000RC仪器服务器可以设置一个阈值,以秒计量,当无输入事件超过这一个规定的阈值时,空闲的客户端将被断开,并保存当前数据。
Note that pointer and keyboard events received from clients prevent their connection to reach the timeout even if the K4000RC Server is configured to ignore those events (see below).
要注意的是:即使仪器服务器设置为忽略那些无输入事件(见下面),
客户端在指示器和键盘接连续收到空闲指令时也要防止达到中断阈值时间(而中断)
