FDA: Tiny bit of melamine OK in most foods
美国FDA不久前说,微量三聚氰胺(小于2.5PPM)对人体无害
去年美国的宠物食品毒死宠物的事件发生后,美国人担心家畜吃了混有三聚氰胺的饲料,把它们的肉污染了。美国FDA是怎么做的呢?他们很快发布公告,说微量三聚氰胺对人体无害,避免了美国的畜牧业遭受不必要的损失。
http://www.usatoday.com/news/health/2008-10-03-melamine-fda_N.htm
WASHINGTON (AP) — Tiny traces of melamine, the chemical that has set off a global food safety scare, are not harmful in most foods, except baby formula, U.S. government experts said Friday.
The Food and Drug Administration said Friday its safety experts have concluded that eating a minuscule amount of melamine — 2.5 parts per million — would not raise health concerns, even if a person ate food every day that was tainted with the chemical."It would be like if you had a million grains of sand and they were all white, and you had two or three that were black, that's kind of the magnitude," said Stephen Sundlof, director of the FDA's food safety program.
The FDA guideline is meant to help federal and state investigators checking for contaminated foods from China at ports of entry and in Asian community groceries around the country. "We are trying to identify products that have levels we are really concerned about, rather than trying to find the last molecule," said Sundlof.
For example, melamine levels in imported Chinese candies recalled last week in California were as high as 520 parts per million, about 200 times greater than the level set on Friday by the FDA for "tolerable" risk.
In China, melamine-tainted formula has sickened more than 54,000 children, mainly with kidney problems, and is being blamed for the deaths of at least four. The industrial chemical has also turned up in products sold across Asia, ranging from candies, to chocolates, to coffee drinks, all of which used dairy ingredients from China.
In the U.S., White Rabbit candies from China were recalled after authorities in California and Connecticut found melamine. And Friday, a New Jersey company announced it was recalling a yogurt-type drink from China, 'Blue Cat Flavor Drink,' after FDA testing found melamine.
No illnesses have been reported in the U.S., but authorities are checking for any telltale increase in reports of kidney problems.
The FDA says infant formula sold here is safe, because manufacturers do not use any ingredients from China. But officials expect more melamine recalls as they continue to test products in ethnic markets.
FDA officials stressed that the melamine risk assessment issued Friday does not mean U.S. authorities will condone foods deliberately spiked with the chemical.
The 2.5 parts-per-million standard is meant to address situations in which the chemical accidentally comes into contact with food. For example, plastic food processing equipment may have been made using melamine, and some of the chemical might find its way into food.
Infant formula sold to U.S. consumers must be completely free of melamine. "There is too much uncertainty to set a level in infant formula and rule out any public health concern," the FDA said.
In China, unscrupulous suppliers appear to have been adding melamine to make watered-down milk seem protein-rich in quality-control tests. That is because melamine is high in nitrogen, as is protein.
Melamine first came to the attention of U.S. consumers last year, when it touched off a massive pet food recall. Chinese suppliers of bulk pet food ingredients were found to have been adding the chemical to artificially boost the protein readings of their products. Thousands of pets here were sickened, and hundreds are believed to have died.
Melamine is harmful to the kidneys. It can cause kidney stones as the body tries to eliminate it, and in extreme cases, life-threatening kidney failure.
Copyright 2008 The Associated Press. All rights reserved. This material may not be published, broadcast, rewritten or redistributed.
矫枉过正?
现在的农药大都是选择性农药,只对害虫有效,只要正确处理,对人体的危害是很轻的。除草剂也是如此,化肥就更不用说了,没有化肥和除草剂的话,你觉得袁隆平的杂交水稻真的能亩产1000公斤?
转基因食品究竟是不是毒药?包括美洲和亚洲在内的很多人已经吃了10年的转基因食品,究竟有多少人被毒死了?或者生了癌症?
奶不能吃了(三聚氰胺),蔬菜也不能吃了(农药),大米也不能吃了(毒大米),肉也不能吃了(激素)……那你打算怎么办?光合作用DIY?
o(∩_∩)o...是不是谁在忽悠谁啊?
