成功率高应该差不多吧,你们后来有用MacTempas再构一次吗?我想改成那天我们算的时候条件,应该也能成功的。
我从来没有做过非晶的模拟……比较weak,
如果是要以模拟像对实验像的话,考虑到非常精确的情况,也许需要?
如果是以重构为目的的话,稍微看下晶体结构细节对得上否就可以了。
加在上和加在下应该是一样的吧,我想,因为都是投影来的,只是计算的时候非晶层多进行了点Fresnel。专门放在模拟里面我没用过。
给你这个脚本吧,是DM里面模拟非晶的。你可以看看参考下,哈,是随机数做的。
Hit ctrl-enter to execute.
Description:
This script creates an image resembling a TEM image of an amorphous specimen
by filtering a random image with a band pass filter.
Copyright ?2001 Gatan Inc.
// Set the height and width of the destinantion image
number width = 512, height = 512
// Create an image of the same size and fill with random signal
image randomImage := RealImage("image", 4, width, height)
randomImage = Random()
// Create another image of the same size to contain the square of the Fourier frequency
image freqSquared := RealImage("Frequency Squared", 4, width, height)
// Set the values of the image to the square of the distance from the image centre (in pixels)
// i.e. the Fourier frequency
freqSquared = (icol-(width/2))*(icol-(width/2)) + (irow-(height/2))*(irow-(height/2))
// Create a complex image of the same size to be a filter
complexImage filter := ComplexImage("Filter", 8, width, height)
// This conditional argument sets the real part of all pixels in the filter image to unity
// iff the value of the corresponding pixel in the frequency squared image falls within
// the specified values. Else the pixel is set to zero.
filter = (freqSquared > 100 && freqSquared < 1000) ? complex(1, 0) : complex(0, 0)
// FFT the randomimage, filter using the filter image, and take the inverse
//transform to yield an 'amorphous' image
image filteredImage := RealIFFT( RealFFT( randomImage ) * filter )
// Finally, set the image name... and display it.
FilteredImage.Setname("Simulated Amorphous Image")
ShowImage( filteredImage )
