这是错误信息:See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.Runtime.InteropServices.COMException (0xD5DA0018): Exception from HRESULT: 0xD5DA0018 at novapiLib.NovaPdfOptionsClass.Initialize(String p_wsPrinterName, String p_wsUserName, String p_wsLicenseKey, String p_wsApplicationName) at Agilent.ChemStation.Util.PDFPrintLib.ChemPDFPrint.InitCommands(Object sender, CoreEventArgs e) at Agilent.ChemStation.hpcoreApi.CoreEventHandler.Invoke(Object sender, CoreEventArgs evarg) at Agilent.ChemStation.hpcoreApi.HpCore.OnPreMacroStart(CoreEventArgs e) at Agilent.ChemStation.hpcoreApi.HpCore.WndProc(Message& m) at Agilent.ChemStation.Util.WinSDKLib.MessageWindow.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box
