An Overview of the Emerging Technologies for Advanced Aseptic Processing
Because of the strong correlation between human involvement and intervention and the potential for product contamination in aseptic processing, production systems in which personnel are removed from critical zones have been designed and implemented. Methods developed to reduce the likelihood of contamination include equipment automation, barriers, and isolator systems. Facilities that employ these advanced aseptic processing strategies are already in operation. In facilities where personnel have been completely excluded from the critical zone, the necessity for room classification based on particulate and environmental microbiological monitoring requirements may be significantly reduced.
The following are definitions of some of the systems currently in place to reduce the contamination rate in aseptic processing:
Barriers— In the context of aseptic processing systems, a barrier is a device that restricts contact between operators and the aseptic field enclosed within the barrier. These systems are used in hospital pharmacies, laboratories, and animal care facilities, as well as in aseptic filling. Barriers may not be sterilized and do not always have transfer systems that allow passage of materials into or out of the system without exposure to the surrounding environment. Barriers range from plastic curtains around the critical production zones to rigid enclosures found on modern aseptic-filling equipment. Barriers may also incorporate such elements as glove ports, half-suits, and rapid-transfer ports.
Blow/Fill/Seal— This type of system combines the blow-molding of container with the filling of product and a sealing operation in one piece of equipment. From a microbiological point of view, the sequence of forming the container, filling with sterile product, and formation and application of the seal are achieved aseptically in an uninterrupted operation with minimal exposure to the environment. These systems have been in existence for about 30 years and have demonstrated the capability of achieving contamination rates below 0.1%. Contamination rates of 0.001% have been cited for blow/fill/seal systems when combined media-fill data are summarized and analyzed.
Isolator— This technology is used for a dual purpose. One is to protect the product from contamination from the environment, including personnel, during filling and closing, and the other is to protect personnel from deleterious or toxic products that are being manufactured.
Isolator technology is based on the principle of placing previously sterilized components (containers/products/closures) into a sterile environment. These components remain sterile during the whole processing operation, since no personnel or nonsterile components are brought into the isolator. The isolator barrier is an absolute barrier that does not allow for interchanges between the protected and unprotected environments. Isolators either may be physically sealed against the entry of external contamination or may be effectively sealed by the application of continuous overpressure. Manipulations of materials by personnel are done via use of gloves, half-suits, or full suits. All air entering the isolator passes through either an HEPA or UPLA filter, and exhaust air typically exits through an HEPA-grade filter. Peracetic acid and hydrogen peroxide vapor are commonly used for the surface sterilization of the isolator unit's internal environment. The sterilization of the interior of isolators and all contents are usually validated to a sterility assurance level of 10 6.
Equipment, components, and materials are introduced into the isolator through a number of different procedures: use of a double-door autoclave; continuous introduction of components via a conveyor belt passing through a sterilizing tunnel; use of a transfer container system through a docking system in the isolator enclosure. It is also necessary to monitor closely an isolator unit's integrity, calibration, and maintenance.
The requirements for controlled environments surrounding these newer technologies for aseptic processing depend on the type of technology used.
Blow/Fill/Seal equipment that restricts employee contact with the product may be placed in a controlled environment, especially if some form of employee intervention is possible during production.
Barrier systems will require some form of controlled environment. Because of the numerous barrier system types and applications, the requirements for the environment surrounding the barrier system will vary. The design and operating strategies for the environment around these systems will have to be developed by the manufacturers in a logical and rational fashion. Regardless of these strategies, the capability of the system to produce sterile products must be validated to operate in accordance with pre-established criteria.
In isolators, the air enters the isolator through integral filters of HEPA quality or better, and their interiors are sterilized typically to a sterility assurance level of 10 6; therefore, isolators contain sterile air, do not exchange air with the surrounding environment, and are free of human operators. However, it has been suggested that when the isolator is in a controlled environment, the potential for contaminated product is reduced in the event of a pinhole leak in the suit or glove.
The extent and scope of an environmental microbiological monitoring of these advanced systems for aseptic processing depends on the type of system used. Manufacturers should balance the frequency of environmental sampling systems that require human intervention with the benefit accrued by the results of that monitoring. Since barrier systems are designed to reduce human intervention to a minimum, remote sampling systems should be used in lieu of personnel intervention. In general, once the validation establishes the effectiveness of the barrier system, the frequency of sampling to monitor the microbiological status of the aseptic processing area could be reduced, as compared to the frequency of sampling of classical aseptic processing systems.
Isolator systems require relatively infrequent microbiological monitoring. Continuous total particulate monitoring can provide assurance that the air filtration system within the isolator is working properly. The methods for quantitative microbiological air sampling described in this chapter may not have sufficient sensitivity to test the environment inside an isolator. Experience with isolators indicates that under normal operations pinhole leaks or tears in gloves represent the major potential for microbiological contamination; therefore, frequent testing of the gloves for integrity and surface monitoring of the gloves is essential. Surface monitoring within the isolator may also be beneficial on an infrequent basis.
