主题:【求助】A LOW signal input on pin 4 of the remote connector generates the error message
浏览0 回复3 电梯直达
人在江湖
安捷伦1100,通过自检,还没打开泵等,就shut down,全红
查看帮助发现如下说明:
An external instrument has generated a shut-down signal on the remote line. Use the acronym in the logbook to determine in which module the fault occurred.The instrument continually monitors the remote input connectors for status signals. A LOW signal input on pin 4 of the remote connector generates the error message.
Probable Causes
?Leak detected in an external instrument with a remote connection to the system.
?Shut-down in an external instrument with a remote connection to the system.
?The degasser failed to generate sufficient vacuum for solvent degassing.
是说远程控制报错么?大家遇到这样的问题么?该咋弄?
柏坡
它提示了三种可能的原因
1.仪器泄漏 与远程控制系统的链接。
2.仪器链接的问题
3.脱气机未达到真空度。
翻译的很生硬大概这个意思吧。
该帖子作者被版主 xky02306992积分, 2经验,加分理由:感谢应助
〓猪哥哥〓
〓猪哥哥〓
在连接插头4号端口输入的低信号产生了这个错误信息
