Standard Arsenic Solution: Transfer 10.0 mL of Arsenic Trioxide Stock Solution to a 1000-mL volumetric flask, add 10 mL of 2 N sulfuric acid, then add recently boiled and cooled water to volume, and mix. Each mL of Standard Arsenic Solution contains the equivalent of 1 µg of arsenic (As). Keep this solution in an all-glass container, and use within 3 days.
标准砷溶液:移取10.0mL三氧化二砷储备液于1000mL容量瓶,加入10mL 2N的硫酸,用新煮沸后冷却的水稀释该溶液至刻度,摇匀。每毫升标准砷溶
液相当于含1µg砷。把该溶液存于全玻璃容器中,在配制后3天内使用。
