主题:【每日一句(段)有奖翻译】<八十八> Terms and Definitions (11)
浏览0 回复2 电梯直达
影子
Percent
“Percent” used without qualification means:
·    For mixtures of solids and semisolids, percent weight in weight;
·    For solutions or suspensions of solids in liquids, percent weight in volume;
·    For solutions of liquids in liquids, percent volume in volume;
·    For solutions of gases in liquids, percent weight in volume.
For example, a 1 percent solution is prepared by dissolving 1 g of a solid or semisolid, or 1 mL of a liquid, in sufficient solvent to make 100 mL of the solution.
arvid2007
百分比
“百分比”常用于没有限制条件的方法:
对于固体和半固体,百分比指的是质量比;
对于溶液或有固体悬浮的溶液,质量在体积中的百分比;
对于溶液,百分比指的是体积比;
对于溶有气体的溶液,质量在体积中的百分比。
例如,一个1%的溶液的制备是通过溶解1g固体或半固体,或者是1毫升溶液,然后用溶剂制成100毫升的溶液。
该帖子作者被版主 hyheying3积分, 2经验,加分理由:积极参与
poorlittle
当“百分比” 一词没有特别定义的情况下:
该帖子作者被版主 hyheying1积分, 2经验,加分理由:积极参与
2011/5/17 13:14:52 Last edit by poorlittle
