参考:使用用标准溶液得到读数平均值制作的校准曲线来测定测试溶液中的乙酯浓度。测量乙酯的峰面积。用下面公式计算乙酯的百分含量。
C=测试溶液的乙酯浓度,以每升毫克表示,由标准溶液的标准曲线的线性内插值来测定(b)
Determine the concentration of acetate in the test solutionusing the c = concentration of acetate in the test solution, inmicrograms per millilitre, determined by linear interpolation of the standard curve for reference solution (b) ;
