主题:【转帖】免费的谱图数据库20个!(转自小木虫)
浏览0 回复6 电梯直达
平凡人
【名称】ChemExper化学品目录CDD (包括MSDS、5000张红外谱图)
【资源简介】
The database contains currently more than 70 000 chemicals, 16000 MSDS, 5000 IR spectra and more than 20 suppliers. It is the only chemical database that lets you SUBMIT your own data!
【检索途径】
You can find a chemical by its molecular formula, IUPAC name, common name, CAS number, catalog number, substructure or physical characteristics
【地址】 http://www.chemexper.be/
【名称】nmrdb.org (NMR谱图数据库及NMR谱图预测)
【资源简介】
This is a web-based approach implementing a new java applet that enables to assign a chemical structure to the corresponding NMR spectrum by simply drawing lines between atoms and automatically characterized signals.
This NMR predictor allows to predict the spectrum from the chemical structure based on Spinus (Structure-based Predictions In NUclear magnetic resonance Spectroscopy), which is an on-going project for the development of structure-based tools for fast prediction of NMR spectra developed by Gasteiger (http://www2.chemie.uni-erlangen.de/services/spinus/index.html). SPINUS - WEB currently accepts molecular structures via a Java molecular editor, and estimates 1H NMR chemical shifts.
【地址】 http://www.nmrdb.org/
【名称】BioMagResBank (BMRB): 多肽、蛋白质、核酸等的核磁共振数据存储库
【资源简介】
Introduction
BioMagResBank (BMRB) is the publicly-accessible depository for NMR results from peptides, proteins, and nucleic acids recognized by the International Society of Magnetic Resonance and by the IUPAC-IUBMB-IUPAB Inter-Union Task Group on the Standardization of Data Bases of Protein and Nucleic Acid Structures Determined by NMR Spectroscopy. In addition, BMRB provides reference information and maintains a collection of NMR pulse sequences and computer software for biomolecular NMR. Access to data in BMRB is free directly from its web site (URL http://www.bmrb.wisc.edu) and ftp site (ftp.bmrb.wisc.edu) and will remain so as public funding permits. The concept of a biomolecular NMR data bank developed under a five-year research grant awarded to the University of Wisconsin-Madison from the National Library of Medicine, National Institutes of Health. This grant was phased out after that period, and a Request for Applications was issued by the NIH for future support of this activity. BMRB at t he University of Wisconsin-Madison won this competition, has been supported since 1 September 1996 by the National Library of Medicine, NIH under grant 1 P41 LM05799. The current award for five years expires on 31 August 2004.
Aims
In collaboration with the Protein Data Bank (PDB, Brookhaven National Laboratories) and Nucleic Acid Data Bank (NDB, Rutgers University), BMRB aims to develop into the collection site for structural NMR data in proteins and nucleic acids. Steps are being taken at BMRB to achieve this capability, which will include transmission of all relevant data to the PDB and NDB collections. In addition, BMRB has the goal of archiving NMR-specific data including assigned chemical shifts, J-couplings, relaxation rates, and chemical information derived from NMR investigations (for example, hydrogen exchange rates and pKa values). In developing these collections BMRB intends to be responsive to the needs and priorities of the scientific community. The operating policy at BMRB is monitored and shaped by its Advisory Board which meets once each year to review progress and set priorities. The Advisory Board is composed of representatives from laboratories that originate and/or use data within the BMRB p urview.
【地址】 http://www.bmrb.wisc.edu/
【名称】NIST Chemistry WebBook
【资源简介】
The November 1998 release of The NIST WebBook is the fifth edition of the NIST Chemistry WebBook. It contains thermochemical data for over 5000 organic and small inorganic compounds, reaction thermochemistry data for over 8000 reactions, IR spectra for over 5000 compounds, mass spectra for over 10,000 compounds, electronic / vibrational spectra for over 3000 compounds, constants of
diatomic molecules (spectroscopic data) for over 600 compounds, Ion energetics data for over 14,000 compounds, and thermophysical property data for 16 fluids There are many avenues for searching the database. Structures are given for most species, as well as common and commercial names.
【检索途径】
Formula Name
Partial formula
CAS registry number
Structure based
Ion energetics
Vibrational and electronic spectra
Molecular weight
Author
【地址】 http://webbook.nist.gov/chemistry
【名称】粉末衍射模式数据库PowBase (Powder Patterns Database)
【资源简介】
PowBase is a "minimum database" of constant wavelength powder patterns. The data files (zipped) contain either a CIF file or a .dat file (the latter can be viewed by WinPLOTR, option INSTRM=0).
The search output produces entry numbers with hyperlink to the raw data (zipped files), the formula, wavelength, a comment, and a reference with email address. Some pertinent hyperlinks may be added, and also a VRML 3D view, sometimes.
【地址】 http://sdpd.univ-lemans.fr/powbase/
【名称】上海有机化学所:化学数据库
【资源简介】
上海有机化学研究所的化学专业数据库由多个数据库组成,注册后可免费使用。可进行化合物结构检索。
化合物结构数据库
收录了1,200,000多个化合物,多库融合检索平台将多个不同类型,不同结构,不同软件支持的本地及异地数据库置于一个统一检索平台,使用户可以同时从各个不同数据库检索信息,也可以只选择一个数据库进行检索。通过全结构检索,子结构检索以及模糊结构检索可查出目标化合物的物化性质,二维、三维结构,红外光谱图,质谱谱图,相关参考文献等。
化学反应数据库
覆盖了国内外化学文献中报道的大量化学反应,检索途径为化学反应物检索,反应产物检索,反应溶剂、催化剂检索及组合检索等,可获取相关反应信息及参考文献等,对反应机理研究,合成路线设计具有相当参考意义。
红外谱图数据库
收录了大约220,000多个化合物,通过特定格式转化的红外光谱文件以峰位检索,强峰检索,功能团检索以及组合检索,也可以通过化合物名称,化合物分子式检索,获取需要的化合物,主要包括其红外光谱图,物化性质以及CA登录号等信息。
质谱谱图数据库
收录了大约12,000多个化合物,检索途径为质荷比检索,丰度检索以及组合检索,可获取化合物质谱谱图,物化性质等信息。
药物与天然产物数据库
覆盖来自不同数据库的药物和天然产物信息资源,其中药物信息1万多条,主要是关于药物的物化性质、相关专利以及参考文献,另外还包括13万多个天然产物信息。
中药与有效成分数据库
将数千年来中国传统中医的临床实践融合成一个内涵丰富疾病用药—中药药材—化合物性质的多层次信息数据库,其中包括了50,000余个处方,1,400多种疾病用药。
【地址】 http://202.127.145.134/scdb/
平凡人
【名称】EPA spectral database
【资源简介】
EPA Reference Absorbance Spectra
The Clean Air Act Amendments (CAAA) was published in November 1990. Title III of the Clean Air Act includes a list of 189 hazardous air pollutants (HAPS) for which test methods must be established. An extractive stack sampling method, using FTIR, has been developed for measuring HAPS. As one of the initial tasks in the project development, reference spectra were developed for as many of the HAPS as possible. Attached is a table which contains the quantitative reference spectral library as of June 1993. The table includes several columns of information for each file. The pathlength is the pathlength of the sample cell used to record that particular spectrum. The TEMP column is the temperature at which the compound was measured. Spectra were recorded for each compound at for at lease two different concentrations when possible. Duplicate spectra were recorded for every concentration for quality assurance purposes. The ASC column is the accepted standard concentration which was assigned b y the chemical standard. The ASC values should be used for data analysis. Duplicate samples were obtained for each concentration. These spectra were developed following the Protocol for Extrative FTIR for Analysis of Gas Emissions . Refer to the FTIR TECHNOLOGY DEVELOPMENT Report for additional information regarding the these spectra.
EPA Reference Spectra Interferograms
Listed are the interferograms from which the EPA Reference Absorbance Spectra were created. Single beam spectra can be created from these interferograms by using the FTPROC program avalible on this site. The Background Interferograms are those interferograms recorded while the absorption cell was evacuated. The Data Interferograms are those interferograms recorded with the analyte present in the absorption cell. The CTS Interferograms are those associated with the recording of the absorption of the Calibration Transfer Standard gas. For more information on the recording of the interferograms please see the report FTIR TECHNOLOGY DEVELOPMENT. The file naming convention used on the interferograms is the same used on the EPA Refernce Absorbance Spectra
【地址】 http://www.epa.gov/ttn/emc/ftir/data.html
【名称】美国标准与技术研究院NIST原子光谱数据库(ASD)
【资源简介】
The Atomic Spectra Database (ASD) contains data for radiative transitions and energy levels in atoms and atomic ions. Data are included for observed transitions of 99 elements and energy levels of 52 elements. ASD contains data on about 900 spectra from about 1 ? (?ngstr?ms) to 200 μm (micrometers), with about 70,000 energy levels and 91,000 lines, 40,000 of which have transition probabilities listed. The most current NIST-evaluated data associated with each transition are integrated under a single listing.
【地址】 http://physics.nist.gov/cgi-bin/AtData/main_asd
【名称】小型光谱数据库下载Optical Databases Download Page
【资源简介】
Here you will find collections of spectra, each contained in SpecManager databases for optical spectroscopy.
Ludmila Tumanova's collection of quantitative IR (13 entries) and FT-IR (2 entries)
【地址】 http://www.acdlabs.com/download/db/uv_ir.html
【名称】ACD/Web Librarian环境下的色谱应用数据库
【资源简介】
The Public Chromatography Applications Database under ACD/Web Librarian contains applications provided by Agilent, Alltech, Eprogen (Eichrom), GL Sciences, Hamilton, Argonaut (Jones Chromatography), Polymer Laboratories, and Regis. The database can be searched by numerous chromatographic parameters, as well as by structure, substructure, and structural similarity. For example, if you work with a novel compound, you will be able to retrieve chromatographic applications that were successfully used to separate compounds with similar chemical structures. This structure-based search capability, combined with the high quality of data and total number of applications (1830 HPLC/GC separations), has proven to be an invaluable resource for chromatographers facing the challenge of new method development.
It's a FREE Service, but you must register first at I-Lab
【地址】 http://www2.acdlabs.com/ilab/
【名称】Atomic Line List (原子吸收、发射性能数据)
【资源简介】
This is a compilation of approximately 923,000 allowed, intercombination and forbidden atomic transitions with wavelengths in the range from 0.5 ? to 1000 μm. It's primary intention is to allow the identification of observed atomic absorption or emission features. The wavelengths in this list are all calculated from the difference between the energy of the upper and lower level of the transition. No attempt has been made to include observed wavelengths. Most of the atomic energy level data have been taken from the Atomic Spectra Database provided by the National Institute of Standards and Technology (NIST).
【地址】 http://www.pa.uky.edu/~peter/atomic/
平凡人
【名称】ECDYBASE (The Ecdysone Handbook)
【资源简介】
The " Ecdysone Handbook " was originally created by René Lafont and Ian D. Wilson and published in 1992 by the Chromatographic Society (Nottingham, U.K.). Its aim was to provide general data on all natural ecdysteroids described so far. Each data sheet contained (whenever available) spectroscopic (UV, IR, MS and NMR) and chromatographic data together with a few selected general references. As the ecdysteroid family continued to increase, a second enlarged edition was published in 1996, but the number of compounds is still growing (more than 300 compounds were described at the onset of year 2000).
Owing to the limited number of people interested by such a Handbook, a printed version is no longer justified, and moreover the problem of updating content was a major one. This led to the idea of developing a new concept, making a proper use of modern communication tools. A decision was taken to transform the Handbook in a database made freely available on the web to anyone interested in ecdysteroids.
【地址】 http://ecdybase.org/
【名称】应用化学数据库
【资源简介】
碳-13核磁共振波谱数据库
  碳-13核磁共振波谱数据库系统始建于1982年,它是国内第一个比较大型的碳-13 NMR谱图数据库系统,主要用于有机化合物结构的自动解析。数据类型包括各类有机化合物的碳-13 NMR谱图数据,如天然产物,金属有机化合物, 毒物等各类化合物。数据项包括化合物名称、分子式、化合物重量、化学位移、多重性、实验条件、相关的文献等。
稀土萃取数据库
  稀土萃取数据库系统始建于1987年,主要用于稀土的分离。稀土萃取数据库的主要数据类型为:中性磷类萃取剂;胺类萃取剂;羧酸类萃取剂;无机酸的萃取。数据项包括萃取剂名称、分子式、被萃成分(金属元素和无机酸)、极性项、稀释剂、辅助配位体、参考文献等。
稀土物理化学性质数据库
  稀土物理化学性质数据库系统始建于1987年,主要用于与稀土相关的材料的研究与设计。数据库中包括氧化物,卤化合物,硫化合物,金属间化合物等40余种化合物的熔点,沸点,生成热,熵,焓等多种物理化学性质。
化合物活性数据库
  化合物活性数据库中包括化合物的CAS登录号,化合物名称,分子式,分子量,活性值等
【地址】 http://www.appchem.csdb.cn/
【名称】质谱:Mass Spectrometry Database,American Academy of Forensic Sciences
【资源简介】
This library is a "subset" of one that has been compiled over a period of many years by Dr. Graham Jones and colleagues in Edmonton, Alberta, Canada. Pure drug spectra, plus a few breakdown products and pure metabolite standards have been edited into a single library. The first version of this library contained about 1500 entries. A separate library of metabolites, endogenous compounds and artifacts is under construction, but may be 1-2 years from completion of the first draft (it's an incredibly time consuming process!!).
【检索途径】
The current library is aafsdrug.zip. Click on the file name to download. This file consists of the component files of this library, compressed with the utility pkzip, into a single "zip" file. This saves space and allows a shorter, easier download than if the individual uncompressed files were available. A list of entries can be downloaded separately as an MS Excel v. 4 spreadsheet file that can be viewed with most spreadsheet and many database programs.
Software Compatibility
Libraries made available by the committee primarily designed to be compatible with HP 5970/71/72/73 series instruments that have PC-based DOS/Windows ChemStation operating systems. See the Software Compatibility page for a fuller discussion and the availability of libraries translated for other mass spectrometers.
【地址】 http://www.ualberta.ca/~gjones/mslib.htm
【名称】SweeT-DB (糖类化合物数据库)
【资源简介】
Sweet-DB includes:
about 50,000 carbank entries
more than 22,000 carbohydrate structures
15,000 publications about 1,000 pubilcations collected via Auto-Sweet-DB
about 10,000 spatial representations generated with sweet.
【检索途径】
SweeT-DB is the main glycosciences data base which allows glycoscientists to find important data for the compound of interest in a compact and well-structured representation. Currently, reference data taken from CarbBank, which is linked to the NCBI PubMed service, NMR data taken from SugaBase , theoretically calculated MS-spectra and 3D coordinates generated with SWEET-II can be retrieved for a given carbohydrate (sub)structure.
Search is supported by formula, exact structure, author or fuzzy author, Fuzzy title, LinucsID, Classification, Composition and Peak Search, etc.
【地址】 http://www.dkfz-heidelberg.de/spec/sweetdb/
【名称】糖类(碳水化合物)拉曼谱图库SPECARB (Raman Spectra of Carbohydrates)
【资源简介】
SPECARB is an experimental database containing Raman spectra of carbohydrates. It is intended to contain solid state Raman spectra of carbohydrates from the monomers and their derivatives to complex polysaccharides. Unless otherwise stated, the spectra are sampled on a Perkin Elmer System 2000 interferometer using a Nd:YAG laser. To obtain comparable spectra they will be recorded using the following parameters
【地址】 http://newton.foodsci.kvl.dk/users/engelsen/specarb/specarb.html
平凡人
【名称】Elemental Data Index (元素的物理数据)
【资源简介】
The Elemental Data Index provides access to the holdings of NIST Physics Laboratory online data organized by element.
【地址】 http://physics.nist.gov/PhysRefData/Elements/cover.html
【名称】eCrystals - Southampton (晶体结构数据共享库)
【资源简介】
The information contained within an entry in this archive is all the underlying data generated during the course of a structure determination from a single crystal x-ray diffraction experiment. This information is freely available and allows the reader to a) assess the validity of the dataset or b) repeat the experiment or c) use the data for further studies.
An individual entry consists of three parts:
Core bibliographic data, such as authors, affiliation and a number of chemical identifiers,
Data collection parameters that allow the reader to assess at a glance certain aspects of the crystallographic dataset,
Files available for download. These files are: visualisations of the raw data (.jpg), the raw data itself (.hkl), experimental conditions (.htm), outputs from stages of the structure determination (_xs.lst, _xl.lst & .res), the final structural result (.cif & .cml) and the validation report of the derived structure (_checkcif.htm).
This archive is running on GNU EPrints open archive software, a freely distributable archive system available from software.eprints.org.
【地址】 http://ecrystals.int.chem.soton.ac.uk/
【名称】FTNMR Spectra in NUTSTM Format
【资源简介】
The FTNMR FID archive (see below) lists a number of 13C, 1H, and APT free induction decay files in Nuts format (a Windows NMR off-line data processing program). Most of these files are also available on another page of the Archive in Felix for Windows format (another off-line NMR data processing program).
Compounds are listed according to increasing carbon number. All the FIDs presently listed below were collected on a 300 MHz spectrometer at Pacific Lutheran University.
【地址】 http://rainier.chem.plu.edu/nutsform.html
yuyingcao
q2046q
非常有用的东东 谢谢!
有些需要安装java才能正常使用
家有田
