主题:原吸的试题,看看我做的对吗?
浏览0 回复9 电梯直达
yaofei
1)When using flame atomic absorption spectroscopy, what is the purpose of adding releasing  agents (i.e. lanthanum) to the standards and samples?
a) To ensure the samples and the standards have similar surface tension and viscosity.
b) To minimize atomization interferences.
c) To increase the flame temperature.
d) To reduce background interferences caused by the acetylene.
e) To eliminate the need for probe rinsing.
我选b
2)When preparing standards for spectroscopic analysis of a sample, why is it important that the standards be similar in general composition (i.e. those constituents present in large quantity) to the unknown sample?
a) To reduce any interferences caused by matrix effects.
b) To reduce chemical inventories in the laboratory.
c) To minimize the risk of using shelf-life expired standards.
我选a
3)What is(are) the purpose(s) of running calibration check samples at the end of an analysis run:
a) To re-verify good instrument calibration.
b) To evaluate instrument drift.
c) To evaluate instrument reproducibility.
d) All of the above
e) Answers ‘B’ and ‘C’ only are correct
不确定
4)In alloy chemistry analysis, a trace element is defined as:
a) The primary or matrix element in an alloy.
b) A reference marker element used to verify detector calibration.
c) A very low concentration residual element.
我选C
tzl75
yaofei
tzl75
原文由 yaofei 发表:
3总觉得都有道理,漂移和重复性也能评估吧?
也是,但是就是校正检查发现飘逸了能怎么样?
yaofei
这是我同学的考题,化学分析简单极了,原吸我也马马虎虎,ICP的就不知道了,你能也帮我看看吗?
tzl75
原文由 yaofei 发表:
等会抽空过去看看
renzhihai
yaofei
全选也觉得不妥,重复性好像应该看重复几次的SD?
难怪我的同学工资是我的n倍,人家不是学分析的考这个题目,而我学分析的还是稀里糊涂的
zjy_95
zhangwuji
