poorlittle回复于2009/05/21
From the sentence “……and a quadruple count was applied to reduce statistical counting errors……” in http://www.nps.gov/history/history/online_books/maritime/naturalsite.pdf , ruojun’s reply seems correct.
何当奇回复于2009/05/25
若军大哥就是做生物方面的,感觉这方面他还是比较权威的。
原文由 yyyyyyyyyang 发表:
请教微生物培养中的“quadruple count”是译为“四倍计数”吗?如果有,具体步骤是什么呢?如果不是,那该如何译?意思又是什么?
谢谢!
参考原文如下:
Spore and yeast suspensions were counted fourfold in Petri dishes using the decimal dilution method.
After microscopic examination and dilution to 1×108 spores per ml, a quadruple count of the spore suspension is carried out on petri dishes。
