AR (Analytical reagent 分析纯);
BC(Biochemical 生化试剂);
BP (British Pharmacopoeia 英国药典);
BR (Biological reagent 生物试剂);
BS (Biological Stain 生物染色剂);
CP (Chemical pure 化学纯);
EP (Extra Pure 特纯);
FCM (For Complexometry 络合滴定用);
FCP (For chromatography purpose 层析用);
FMP (For microscopic purpose 显微镜用);
FS (For synthesis 合成用);
gc (Gas chromatography
气相色谱);
GR (Guaranteed reagent 优级纯);
HPLC (High Preussuer Liquid chromatography 高压
液相色谱);
Ind (Indicator 指示剂);
LR (Laboratory reagent 实验试剂);
OSA (Organic analyfical standard 有机分析标准);
PA (Pro analysis 分析用);
Pract (Practical use 实习用);
PT (Primary eragent 基准试剂);
Pur (Pure purum 纯);
Puriss (Purissmum 特纯);
SP (Spectrum pure 光谱纯);
Tech (Techincal grade 工业用);
TLC (Thin Layer chromatography 薄层色谱);
UV (Ultra violet pure 分光纯、光学纯、紫析分光光度纯)
