主题:【原创】summary report with compound 和 calculate
浏览0 回复2 电梯直达
女人街连锁
安捷伦7890 5975c,  Quantitate菜单下的“ calculate”  和“summary report with compound ” ,有什么区别?
手动积分之后进行计算,只能使使用“summary report with compound groups” 才有效果,“ calculate” 没效果。
您可能想找: 技术咨询 询底价
symmacros
Summary Report with Compound Groups
This produces a standard summary report with additional summed groups.
Groups are based on the spelling of compound names, regardless of retention times. For example, if an analysis identifies compounds named xylene-m, xylene-p, and xylene-o, a summed group can be created by specifying xylene as the group name. The group information appears at the bottom of the report (the numbers are invented for this example):
Named Group:xylene's
Summed Responses 15904
Summed Amounts 137 ng/ml
Number of groups:3
Note that if the compounds had been named m-xylene, p-xylene, and o-xylene, grouping would not be possible.
Up to 6 named groups can be defined.
带化合物分组的摘要报告
此操作将生成包含其他汇总组的标准摘要报告。
这些组基于化合物名称的拼写方式,而不考虑保留时间。例如,如果分析可以识别名为 xylene-m、xylene-p 和 xylene-o 的化合物,则可以通过将 xylene 指定为组名称来创建汇总组。组信息将显示在报告底部(专为本例创建了编号):
已命名组: xylene's
汇总的响应:  15904
汇总量: 137 ng/ml
组数:  3
请注意:如果化合物命名为 m-xylene、p-xylene 和 o-xylene,将无法进行分组。
最多可以定义 6 个已命名组。
该帖子作者被版主 learner19992积分, 2经验,加分理由:谢应助!
2011/11/11 20:50:14 Last edit by jimzhu
symmacros
calculate计算
对当前文件进行定量分析,并生成定量分析报告。
summary report with compound groups带化合物分组的摘要报告....
生成总结定量报告,其中目标化合物相互组合并根据共享名称汇总在一起。
