50.9 | 51 | 51.1 | 52 | 52.1 | 52.2 |
100 | 80 | ||||
101 | 90 | ||||
102 | 96 | ||||
103 | 111 | ||||
104 | 112 | ||||
105 | 113 |
原文由 symmacros(jimzhu) 发表:多谢你答复,前面只是举个例子,这是部分数据,都还没整理
楼主能不能把数据列表一下,方便看。50.9,51,51.1可以看作同一离子碎片。
38.1 | 258 | 38 | 260 | 37.9 | 725 | 36 | 239 | 36 | 270 | ||||
39.2 | 6747 | 39.1 | 6851 | 39.1 | 6194 | 38 | 487 | 38.1 | 539 | ||||
40.1 | 21152 | 40.1 | 21632 | 40 | 21288 | 39.1 | 6434 | 39.1 | 6178 | ||||
41.1 | 24304 | 41.1 | 21928 | 41.1 | 20792 | 40.1 | 21048 | 40 | 22800 | ||||
42.1 | 2446 | 42.1 | 1995 | 42.1 | 1796 | 41.1 | 18104 | 41.1 | 18560 | ||||
43.1 | 8358 | 43.1 | 8697 | 43.1 | 8363 | 42.2 | 1851 | 42.1 | 2362 | ||||
44 | 3857 | 44 | 3250 | 44 | 4360 | 43.1 | 7575 | 43.1 | 7295 | ||||
45.1 | 1069 | 45.1 | 1011 | 45.2 | 628 | 44 | 4692 | 44.1 | 4631 | ||||
50.1 | 695 | 50.1 | 360 | 50.1 | 508 | 45 | 715 | 45 | 355 | ||||
51.1 | 1437 | 51.1 | 1585 | 51.1 | 1581 | 46.7 | 183 | 50 | 753 | ||||
51.9 | 506 | 52.2 | 570 | 52.1 | 632 | 49.9 | 696 | 51.1 | 1827 | ||||
52.2 | 496 | 53.1 | 4660 | 53.2 | 4748 | 51.1 | 2219 | 52.2 | 742 | ||||
53.1 | 5464 | 54.2 | 1155 | 54 | 1064 | 52.2 | 897 | 53.1 | 4900 |
54.1 | 1660 | 55.1 | 11997 | 55.1 | 14090 | 53.1 | 4850 | 54.2 | 789 | ||||
55.1 | 13633 | 56.2 | 5389 | 56.1 | 6055 | 54.1 | 1543 | 55.1 | 11766 | ||||
56.1 | 6403 | 57.1 | 3983 | 57.1 | 3550 | 55.1 | 14694 | 56.1 | 5064 | ||||
57.1 | 3026 | 58.2 | 341 | 58 | 673 | 56.1 | 5557 | 57 | 2677 | ||||
58 | 339 | 59.1 | 463 | 59.1 | 423 | 57.1 | 3305 | 58.1 | 259 | ||||
59 | 645 | 59.9 | 245 | 60.1 | 214 | 58.1 | 344 | 59 | 396 | ||||
60 | 205 | 63.2 | 410 | 63 | 704 | 58.9 | 155 | 61.7 | 254 | ||||
61.9 | 288 | 64.1 | 237 | 64.1 | 214 | 60.1 | 295 | 63 | 591 | ||||
63.1 | 477 | 65.1 | 2195 | 65 | 2636 | 63 | 560 | 65 | 2294 | ||||
64 | 221 | 66.1 | 961 | 66 | 709 | 65.1 | 3269 | 66.1 | 1204 | ||||
65 | 1816 | 67.1 | 19504 | 67.1 | 19552 | 66 | 818 | 67.1 | 17400 | ||||
66.1 | 810 | 68.2 | 7002 | 68.1 | 6681 | 67.1 | 16880 | 68.1 | 7124 | ||||
67.1 | 18544 | 69.1 | 23112 | 69.1 | 22128 | 68.1 | 7082 | 69.1 | 20224 | ||||
68.1 | 8455 | 70.2 | 4586 | 70 | 4099 | 69.1 | 22008 | 70.1 | 3997 | ||||
69.1 | 24040 | 71.1 | 7029 | 71.1 | 5600 | 70.1 | 3381 | 71.1 | 4748 |
70.1 | 4466 | 71.9 | 597 | 71.9 | 394 | 71.1 | 5574 | 72 | 456 | ||||
71.1 | 6141 | 73.2 | 232 | 73 | 157 | 72 | 678 | 73.2 | 313 | ||||
72.1 | 844 | 74 | 242 | 77.1 | 3965 | 73 | 385 | 74.1 | 364 | ||||
72.9 | 168 | 77.1 | 4493 | 78.2 | 1356 | 74.9 | 310 | 77 | 4902 | ||||
77.1 | 4128 | 78.1 | 1083 | 79.1 | 7548 | 76.1 | 173 | 78.1 | 1200 | ||||
78 | 765 | 79.1 | 7941 | 80 | 2263 | 77.1 | 4299 | 79.1 | 7800 | ||||
79.1 | 7912 | 80 | 2409 | 81.1 | 21592 | 78.2 | 728 | 80 | 1852 | ||||
80.2 | 2073 | 81.1 | 22296 | 82.1 | 11779 | 79.1 | 8433 | 81.1 | 20824 | ||||
81.1 | 23112 | 82.1 | 12486 | 83.2 | 3846 | 80 | 2206 | 82.1 | 9320 | ||||
82.1 | 12433 | 83.1 | 3663 | 84.1 | 2587 | 81.1 | 21040 | 83.1 | 3666 | ||||
83.1 | 3682 | 84 | 2641 | 85 | 1614 | 82.1 | 11198 | 84 | 2569 | ||||
84.2 | 1908 | 85.1 | 1546 | 86 | 722 | 83.1 | 4914 | 85.3 | 888 | ||||
85.1 | 1288 | 86.1 | 603 | 89 | 359 | 84.1 | 1879 | 86 | 599 | ||||
86 | 762 | 89 | 271 | 91.1 | 6084 | 85.1 | 1137 | 87.1 | 265 | ||||
86.9 | 166 | 91.1 | 5601 | 92 | 1393 | 86 | 638 | 91.1 | 5847 | ||||
91.1 | 5981 | 92 | 1356 | 93.1 | 9406 | 87 | 229 | 92 | 1707 |
92 | 1626 | 93.1 | 7161 | 94.1 | 1817 | 89.1 | 262 | 93.1 | 7667 | ||||
93.1 | 8431 | 94 | 1931 | 95.1 | 17800 | 91.1 | 6277 | 94.1 | 2451 | ||||
94.1 | 2319 | 95.1 | 15557 | 96.1 | 3354 | 92 | 1362 | 95.1 | 15528 | ||||
95.1 | 15814 | 96.1 | 3066 | 97.1 | 2047 | 93.1 | 8155 | 96.1 | 3069 | ||||
96.1 | 3248 | 97.2 | 1912 | 98.1 | 934 | 94 | 1948 | 97 | 2139 | ||||
97 | 1552 | 98 | 1359 | 98.9 | 351 | 95.1 | 16376 | 97.9 | 1550 | ||||
98 | 1315 | 99.1 | 759 | 102.9 | 237 | 96.1 | 2614 | 99 | 718 | ||||
98.9 | 390 | 101 | 223 | 104 | 193 | 97.1 | 1826 | 101.2 | 191 | ||||
100.1 | 189 | 102.9 | 415 | 105.1 | 3756 | 97.9 | 941 | 102 | 289 | ||||
101.2 | 283 | 103.5 | 188 | 106.1 | 828 | 98.2 | 972 | 102.8 | 606 | ||||
102.2 | 226 | 104 | 304 | 107.1 | 2891 | 99.1 | 691 | 104 | 390 | ||||
103.2 | 531 | 105.1 | 3027 | 108.1 | 1166 | 101.7 | 170 | 105 | 2713 | ||||
105.1 | 3006 | 106.2 | 635 | 109.1 | 15326 | 102.8 | 331 | 106 | 468 | ||||
106 | 855 | 107.2 | 2233 | 110.1 | 3960 | 103.2 | 334 | 107.1 | 2159 | ||||
107.1 | 2298 | 108.3 | 939 | 111 | 2553 | 104.2 | 333 | 108.3 | 572 | ||||
107.9 | 1280 | 109.1 | 14319 | 112.2 | 1348 | 105 | 3919 | 109.1 | 15856 | ||||
109.1 | 13650 | 110.1 | 3604 | 113.1 | 547 | 106.1 | 579 | 110.1 | 4666 |
