表1 样品前处理微波消解程序
Tab1.Microwave digestion procedure of sample pre-treatment
Nr | t | E[w] | T1[℃] | P[bar] |
1 | 00:10:00 | 800 | 160 | 35.0 |
2 | 00:05:00 | 800 | 190 | 35.0 |
3 | 00:20:00 | 800 | 190 | 35.0 |
表2 标准浓度结果一览表
Tab2 The results of standard
样品ID | 浓度(μg) | 吸光度(Abs) |
1 | 0.200 | 0.011 |
2 | 0.500 | 0.033 |
3 | 1.000 | 0.070 |
4 | 2.000 | 0.150 |
5 | 3.000 | 0.226 |
6 | 4.000 | 0.296 |
7 | 5.000 | 0.369 |
表4 样品回收率试验结果
Tab4. The testing rusults of recovery
样品 编号 | 本底值 (μg) | 标准加入量 (μg) | 测定值 (μg) | 回收率 (%) |
1 | 20.5 | 10.0 15.0 | 29.6 34.3 | 91.0 92.0 |
2 | 31.6 | 10.0 15.0 | 41.1 45.3 | 95.0 91.3 |
3 | 40.3 | 20.0 | 60.8 | 102.5 |
表5精密度实验结果
Tab5 The testing results of precisvon
样品 编号 | 样品测定结果(mg/kg) | |||||||
1 | 2 | 3 | 4 | 5 | 6 | RSD % | ||
1 | 15.6 | 15.5 | 15.6 | 15.7 | 15.5 | 15.7 | 15.6 | 0.5 |
2 | 31.2 | 31.3 | 31.2 | 31.4 | 31.3 | 31.2 | 31.3 | 0.3 |
3 | 50.7 | 50.8 | 50.6 | 50.7 | 50.6 | 50.7 | 50.7 | 0.2 |
表3铝含量检测结果
Tab3.The testing results of Aluminium content
样品 | 吸光度 | 浓度(μg) |
水样1 | 0.001 | 0.0547 |
水样2 | 0.000 | 未检出 |
水样3 | 0.000 | 未检出 |
膨化食品1 | 0.046 | 0.656 |
膨化食品2 | 0.041 | 0.589 |
膨化食品3 | 0.036 | 0.522 |
水产品1 | 0.019 | 0.295 |
水产品2 | 0.023 | 0.349 |
水产品3 | 0.026 | 0.389 |
