其实需不需要稳压器要看原子化时,电压降了多少,如果230v静态电压压降10-20伏还是可以的,零地电压在原子化时小于3v最好,主要考察原子化时,而不是静态的!如果配的话AA800需要10KVA的能耐受原子化时90A 3秒冲击的稳压器,一般没人配,配选这种10 KVA True On-Line Power Conditioned UPS It meets the minimum surge current handling rating of 90 A for about 3 seconds during Atomization stage peak power. The Perkin Elmer part number for the 10.0 KVA UPS is N0777613.
