主题:【第十七届原创】液液萃取-气相色谱串联质谱法测定生活饮用水中土臭素和2-甲基异莰醇
浏览0 回复4 电梯直达
ghyl
维权声明:本文为binshengliang原创作品,本作者与仪器信息网是该作品合法使用者,该作品暂不对外授权转载。其他任何网站、组织、单位或个人等将该作品在本站以外的任何媒体任何形式出现均属侵权违法行为,我们将追究法律责任。
摘要:
建立了液液萃取-气相色谱串联质谱法测定生活饮用水中土臭素(GSM)和2-甲基异莰醇(2-MIB)的方法,样品加入氯化钠、内标物质2-异丁基-3-甲氧基吡嗪,经乙酸乙酯液液萃取、浓缩,气相色谱串联质谱法进样检测,内标法定量。实验结果表明:曲线的线性相关系数均在R2>0.999,方法检出限分别为2.7ng/L、3.0ng/L,相对标准偏差(RSD)为96%~118%,加标回收率为0.7%~4.7%,均满足GB5749-2022的检测要求。该方法解决了GSM、2-MIB液液萃取重现性低、准确度不高、萃取效率低的问题,样品前处理简单,仪器设备简单,方便推广。具有分析快速、灵敏度高、重现性好的优点。
关键词:土臭素;2-甲基异莰醇;液液萃取;气相色谱串联质谱法
Determination of geosmin and 2-Methylisoborneol indrinking water by liquid-liquid extraction-gas chromatography-tandem massspectrometry
Abstract:ObjectiveA liquid-liquid extraction-gaschromatography-tandem mass spectrometry method was developed for thedetermination of GSM and 2-Methylisoborneol in drinking water, sodium chlorideand internal standard substance 2-isobutyl-3-methoxypyrazine were added intothe sample, and the sample was extracted, concentrated and ethyl acetate byliquid-liquid extraction, analyzed by gas chromatography-tandem massspectrometry, and quantified by internal standard method. The results showedthat the linear correlation coefficients of the curves were all in the range ofR2 >0.999. The detection limits were 2.7 ng/L and 3.0 ng/Lrespectively. The relative standard deviation (RSD) was 96% ~ 118% , and therecoveries were 0.7% ~ 4.7% , all meet the requirements of GB 5749-2022. Themethod solves the problems of low reproducibility, low accuracy and lowextraction efficiency of GSM and 2-MIB liquid-liquid extraction. The inventionhas the advantages of fast analysis, high sensitivity and good reproducibility.
Keywords:Geosmin; 2-methylisoborneol;Liquid-liquid extraction; Gas chromatography tandem mass spectrometry
土臭素(GSM)和2-甲基异莰醇(2-MIB)由放线菌、蓝藻等微生物代谢产生,往往会伴随夏季藻类暴发与代谢,导致地表水的水体中浓度大幅上升[1],是造成生活饮用水具有土霉味和腥臭味的主要原因。
生活饮用水中的土臭素(GSM)和2-甲基异莰醇(2-MIB)是目前造成生活饮用水具有土霉味和腥臭味的主要原因,主要是由放线菌、蓝藻等微生物代谢产生,往往会伴随夏季藻类暴发与代谢,导致地表水的水体中浓度大幅上升[1]。人的嗅觉对其极为敏感,GSM和2-MIB分别在1ng/L~10ng/L和5 ng /L ~10 ng /L时就能被闻到[2]。尽管它们不一定会对人体的健康造成威胁,但是因口感和味道不佳,常常使人们怀疑水质遭到污染而无法放心食用。近年来,随着工业的发展,突发嗅味事件时有发生[1]。新版《生活饮用水卫生标准》(GB 5749-2022)更是加大感官指标的关注,新增列入土臭素(GSM)和2-甲基异莰醇(2-MIB)两种典型土霉味物质。因此建立快速、灵敏度高、成本低、适宜大范围推广的检测方法十分必要。
分析检测嗅味物质的方法主要有感官分析法[3]- [4]和仪器分析法[5]- [4]两类,感官分析法因依靠个人嗅觉加以判断,存在无法准确定量、主观因素影响较大、环境要求较高等问题,因此应用受到一定限制。仪器分析法以气相色谱[5]气相色谱串联质谱法为主。嗅味物质目前主要前处理方法有固相微萃取法[6]- [7]、吹扫捕集[8]、固相萃取[9]- [10]、液液萃取[11]等;固相微萃取技术虽然操作简便无需有机溶剂萃取效率相对较高、结果准确,精密度高,但全自动固相微萃取价格昂贵,一般实验室难以承担;手动固相微萃取则需手动萃取及进样,检测效率不高,不适合大规模检测,且两种方式均存在萃取范围较窄,萃取纤维头价格昂贵、易碎、使用寿命短等问题。吹扫捕集是非平衡态连续萃取,是几乎能将所有的被测物萃取出来的定量萃取方法,故灵敏度较高,但设备昂贵,且吹扫过程耗费大量的惰性气体,使用成本较高。固相萃取不需要大量的有机溶剂,简化了预处理过程,避免了不必要的污染,但固相萃取所需样品体积大、上样及氮吹耗时较长,且准确性和回收率低于液-液微萃取法。虽然液液萃取存在方法的回收率和重现性差的问题,但其具有处理量大、分离效果好可连续操作、成本较低且易于操作等特点,是一种快速有效、经典适用的水样富集分析方法目前,液液萃取嗅味物质的相关报道主要用到的溶剂是己烷和二氯甲烷,用乙酸乙酯作萃取剂的报道较少;同时液液萃取嗅味物质大多以外标法定量为主,以2-异丁基-3-甲氧基吡嗪作为内标法定量,在液液萃取中尚无相关报道。本文以乙酸乙酯作为液液萃取溶剂,萃取效率高,解决液液萃取回收率低的问题,而以2-异丁基-3-甲氧基吡嗪为内标,内标法定量,解决了液液萃取重现差的问题。本方法操作简单、检出限低、准确度高、重现性好,成本较低,且能满足GB5749-2022对土臭素和2-甲基异莰醇的要求。
实验部分
1.1主要仪器与试剂
GCMS-2010Ultra气相色谱质谱联用仪(日本岛津);R-1001VN型旋转蒸发仪(郑州长城科工贸有限公司);KL512型氮吹仪(北京康林科技有限公司);涡旋混合器(VORTEX-5);数字可调移液器(BRAND);SH-Rxi-5SIl MS色谱柱(30m×0.25mm×0.25μm,日本岛津);正己烷、二氯甲烷、乙酸乙酯(德国默克,色谱纯);无水硫酸钠、氯化钠(400℃烘2h);甲醇中土臭素和2-甲基异莰醇混标(100μg/mL,北京北方伟业计量技术研究院);2-异丁基-3-甲氧基吡嗪(100μg/mL,Tmstandard)。
1.2 标准溶液的配制
土臭素和2-甲基异莰醇混合标准储备液(1μg/mL):准确移取浓度为100μg/mL的土臭素和2-甲基异莰醇混标0.1mL于10mL容量瓶中,用乙酸乙酯定容至刻度,摇匀备用。
2-异丁基-3-甲氧基吡嗪内标储备液(10μg/mL):准确移取浓度为100μg/mL的2-异丁基-3-甲氧基吡嗪标液1.00mL于10mL容量瓶中,用乙酸乙酯定容至刻度,摇匀备用。
标准系列工作溶液:准确移取浓度为1μg/mL的土臭素和2-甲基异莰醇混合标准储备液10、50、100、200、500μL;加入10μL浓度为10μg/mL2-异丁基-3-甲氧基吡嗪内标储备液,乙酸乙酯定容至10mL,配置成标准溶液浓度为1,5,10,20,50ng/mL;内标为10ng/mL的系列标准溶液。
1.3仪器条件
1.3.1气相色谱条件  色谱柱: SH-Rxi-5SIlMS色谱柱(30m×0.25mm×0.25μm);程序升温:60保持2.5min?以8/min升温至250℃?保持5min;进样口:250;柱流量:1.02mL/min?线速率控制模式;线速率:36.9mL/min;进样模式:不分流。
1.3.2质谱条件  离子源:EI源,离子源温度230℃;接口温度280℃;检测器电压0.90 kV;溶剂延迟时间2 min;扫描模式:选择离子检测(SIM)。土臭素、2-甲基异莰醇和2-异丁基-3-甲氧基吡嗪的选择性离子参数和保留时间如表1所示。
表1 土臭素、2-甲基异莰醇和2-异丁基-3-甲氧基吡嗪的选择性离子参数和保留
项目名称
保留时间/min
定量离子(m/Z)
定性离子(m/Z)
土臭素
14.603
112
125
2-甲基异莰醇
10.628
95
107,135
2-异丁基-3-甲氧基吡嗪
10.294
124
94,151
1.4样品处理
500mL水样移入1L分液漏斗中,加入20g氯化钠,加入浓度为1μg/mL2-异丁基-3-甲氧基吡嗪内标储备溶液10μL,轻轻振摇;随后加入50mL 有机溶剂,轻轻震荡,放气,而后手动剧烈震荡萃取2 min,静置分层,将上层萃取液用无水硫酸钠脱水后转移至鸡心瓶中;下层水相再次加入50 mL乙酸乙酯,重复上述萃取步骤,经无水硫酸钠脱水后合并有机相;萃取获得的有机相先用R-1001VN型旋转蒸发仪45℃水浴蒸发至5mL左右,全部转移至氮吹管中,鸡心瓶中再加入2mL乙酸乙酯清洗,用涡旋混匀器混匀后,转移至氮吹管中。使用KL512型氮吹仪进行浓缩,控制氮气流速, 避免形成液面涡流, 45℃氮吹浓缩至1.0mL , 待上机分析。
2 结果与讨论
2.1实验条件的确定
2.1.1萃取剂选择
萃取溶剂对化合物的溶解性是影响萃取效率的最重要因素,而土臭素和2-甲基异莰醇的极性相对较大,所以本实验选择文献报道较多的萃取试剂正己烷、二氯甲烷,同时根据相似相容的原理,极性较大的溶剂对土臭素和2-甲基异莰醇萃取效果更好。而极性乙酸乙酯>二氯甲烷>正己烷,因此选择这三种萃取试剂进行比较。根据目标物峰面积大小,判断萃取效果。如图1所示。试验表明,乙酸乙酯萃取效果更好,其次是二氯甲烷,最后才是正己烷,符合上述极性推断萃取效率,且乙酸乙酯也是三者中毒性最低的,故选择乙酸乙酯作为萃取溶剂。
图1不同萃取剂对峰面积的影响
2.1.2萃取次数对回收率的影响
  量取500mL含有10ng/L  GSM、2-MIB浓度的水样, 混匀后, 按照1.4的样品前处理过程, 上机测试,用外标法定量计算目标物的回收率,以此对比萃取次数分别为1次、2次时的效果,  萃取1次时GSM、2-MIB的回收率分别为63%和78%,而萃取两次的回收率为90%和101%,可见萃取两次的回收率更高,且已满足前处理时对目标物回收率的要求, 故确定本试验前处理萃取次数为 2次。
2.1.3萃取体积的选择
采用液液萃取法时,萃取剂的体积一般为样品体积的1/10~1/3为宜。根据GB/T 5750.8-2023中GSM、2-MIB的检出限,本方法水样的富集体积为500mL,对比乙酸乙酯萃取体积为30 mL,40 mL,50 mL,60 mL时对目标物质峰面积的影响。结果见图2。由图2可见,当萃取体积达到50mL后,增加乙酸乙酯萃取体积对GSM、2-MIB萃取效率影响不大,考虑加大萃取体积增加经济成本,所以选择乙酸乙酯的萃取体积为50mL。
图2不同萃取剂对峰面积的影响
2.1.4萃取时间的选择
移取取500mL浓度为20ng/L 的GSM、2-MIB的水样,在其他条件不变情况下,考察了萃取时间分别为1min、2min、3min时对峰面积的影响,结果见图3。结果表明:由图3可知,萃取时间为2min与3min相比,GSM、2-MIB峰面积变化不大,萃取2min已经完全能满足使用要求,萃取3min虽目标物峰面积更高, 但操作步骤更为繁琐,试剂、时间耗费更多。因此萃取时间为2 min。
图3不同萃取时间的影响
2.1.5氯化钠加入量的选择
加入盐析剂氯化钠的量是影响萃取效率的一个重要因素, 足量盐析剂可确保GSM、2-MIB从水中完全析出, 从而进入到有机溶剂中, 用量不足则会导致萃取不完全, 回收率降低。本实验考察了氯化钠加入量分别为10g、15g、20g、25g 时对峰面积的影响,结果见图4。结果表明:由图4可知,当氯化钠加入量为20g以后,GSM、2-MIB峰面积变化不大,故氯化钠加入量为20g。
图4氯化钠加入量对峰面积的影响
2.1.6浓缩方式的选择
浓缩方式是影响富集效率的一个重要因素,不当的浓缩方式会引起目标物的损失。目前主要的浓缩方式主要有旋转蒸发和氮吹两种。而水中的异嗅物质多为挥发性或半挥发性有机物,因此选择合适的浓缩方式尤为重要。因本试验萃取体积为50mL,萃取两次,大约100mL左右,单纯用氮气吹干用气量比较大,且用时较长。故本文采取旋转蒸发和旋转蒸发与氮气联用进行比较。用旋转蒸发蒸至近干,再定容至1.00mL时,GSM的回收率为39.3%2-MIB的回收率为19.7%。而先用旋转蒸发仪蒸发至5mL左右,再用氮气吹至1.00mLGSM的回收率为89.7%2-MIB的回收率为101%。故选择先用旋转蒸发蒸去大部分萃取溶剂后,再用氮气吹至1.00mL效果更好,即可以回收大部分萃取溶剂,避免污染环境,又可保证目标物的回收率。
2.2标准曲线的线性关系及检出限
在优化试验条件下,以标准系列中的物质浓度为横坐标,以目标物质的峰面积与内标物的比值为纵坐标,绘制工作曲线,结果见表1。同时以3倍信噪比表示方法检出限,对应浓度即为最低检出浓度。结果见表2,可见,两种物质的检出限均能够满足GB 5749-2022的要求。
2GSM和2-MIB表线性回归方程及方法检测限
组分名称
标准曲线回归方程
相关系数()
检出限(μg/L)
GSM
y=0.102412x0.001045
0.9995
2.7
2-MIB
y=0.109154x0.025366
0.9996
3.0
2.3方法的准确度及精密度
3500mL纯水,分别加入1ng10ng50ngGSM2-MIB混合标准溶液,每组平行测定6,计算平均回收率和相对标准偏差(RSD),测定结果见表3。测得回收率在96%~118%RSD0.7%~4.7%,表明该方法具有较好的准确度与精密度。
3GSM和2-MIB平均回收率及精密度(n=6)
化合物
加入量(ng
测得平均值(ng
回收率(%
RSD(%)
GSM
1
1.18
118
3.9
10
11.49
115
2.1
50
49.6
99.2
0.8
2-MIB
1
0.961
96.1
3.4
10
9.723
97.2
4.7
50
49.21
98.4
0.7
2.4实际样品的测定
分别运用优化后的液液萃取方法和GB/T 5750.8-2023标准固相微萃取方法测定了某市自来水厂重要工艺段中的嗅味物质?测定结果见表 1
3某自来水厂工艺节点水样测定结果
工艺节点
液液萃取测定结果(ng/L)
固相微萃取测定结果(ng/L)
GSM
2-MIB
GSM
2-MIB
沉淀池出口
11.0
104
9.7
121
碳滤池出口
未检出
7.6
未检出
8.4
出厂水
未检出
未检出
未检出
未检出
由测试结果可知,沉淀池出口的水样均含有GSM2-MIB,其中2-MIB含量较高,经活性炭过滤后能去除大部分2-MIB,而出厂水均未检出GSM2-MIB
3 结论
本方法根据土臭素和2-甲基异莰醇极性大的特点,选取乙酸乙酯作为萃取剂,同时对萃取次数、萃取剂体积、萃取时间和氯化钠加入量等进行了优化,提高了萃取效率,参照GB/T 5750.8-2023标准,在液液萃取中引入2-异丁基-3-甲氧基吡嗪作为内标,解决了液液萃取准确度不高、重现性不好的问题。旋转蒸发和氮吹联合使用,利用旋转蒸发回收大部分萃取溶剂,避免污染环境,提高检测效率,而氮吹则提高土臭素和2-甲基异莰醇的回收率。两种物质在1.050.0 ng/mL范围内线性良好,检出限分别为2.7 ng/L 3.0 ng/L在低、中、高3个加标水平下的回收率为96%~118%RSD0.7%~4.7%。本方法操作简单、检出限较低、准确度高、重现性好,检测成本较低,可用于生活饮用水中土臭素和2-甲基异莰醇的测定。
参考文献
1]张永鑫,仇付国,王春苗,等.我国饮用水嗅味问题的发生、主要嗅味物质及来源[J.环境科学学报,20234312:65-75.
ZHANGYongxinQIU FuguoWANG Chunmiaoet al.The occurrencemain odorants and sources of drinking water odor problems in ChinaJ.Acta Scientiae Circumstantiae, 2023,43(12) : 65-75.
2]郭继征,王敬敏.生活饮用水主要致嗅物质及其处理[J.工业技术与职业教育,201614( 2) : 101118
Guo Jizheng, Wang Jingmin. Main odor causing substancesin drinking water and processing[ J ] . Industrial Technology and Vocational Education,2016,14(2) : 10-11,18.
3JEROEN H M,BARTELS,BRADY B M, etal. Trainingpanelists for the flavor profile analysis          method[J].JAWWA,198779:1-26.
4]张杨,张福全,等. 嗅味层次感官分析法在水质检测中的应用[J].产业与科技论坛,201413(20):74-75.
  ZhangYang, Zhang Fuquan, et al.Application of smell-taste hierarchical sensoryanalysis in water quality detection [ J ] . Industry and Science Tribune,2014,13(20) : 74-75.
5]马晓雁,高乃云,李青松,等.气相色谱法测定饮用水中痕量土臭素和二甲基异冰片[J].分析测试学报,200726(2):267-269.
    Ma Xiaoyan, Gao Naiyun, Li Qingsong, et al. Determination of trace geosmin in and2-methylisobomeol in drinking water by Gas chromatography[ J ]. Journal of InstrumentalAnalysis, 26(2) : 267 -269.
6]周广安,陈漪洁,潘慧慧,等.全自动固相微萃取-气相色谱串联质谱法检测水中土臭素和2-甲基异莰醇[J]. 净水技术,2021,405:46-50.
ZHOU G ACHEN Y JPAN H Het alAutomatic detection method of 2-MIB andGSM in water by SPME-GC-MS /MSJ].Water Purification Technology2021,40(5): 4650
7]蔺洁,于彤. 气相色谱质谱法测定水中土臭素和二甲基异莰醇[J].供水技术,2017,114:53-54.
Lin Jie, Yu Tong. Determination of geosmin and 2-methylisobomeol in water by gas chromatography-mass spectrometry [ J ] .WaterTechnology, 2017,11(4) : 53-54.
8]乐洋,孙坚伟.吹扫捕集气相色谱质谱联用测定水中二甲基异莰醇和土臭素[J]. 净水技术,2015,344:55-59.
    Le YangSun Jianwei. Determination of 2-Methylisoborneol and Geosmin inWater by Purge and Trap Technology with Gas Chromatography /Mass Spectrometry( GC/MS)[J]. Water Technology, 2015,344:55-59.
9]李福安,张焕伟,巢猛,等.固相萃取-气相色谱法测定土臭素和2-甲基异冰片[J]. 供水技术,2011,52:54-55.
    Li Fu'an, Zhang Huanwei,Chao Meng, et al. Solid-Phase Extraction-Gas Chromatography Method for theDetermination of Geosmin and 2-Methylisoborneol [J]. WaterTechnology,2011,52:54-55.
10]宋帅帅,王晓波,田立平,等.固相萃取-气质联用测定水体中的土臭素和二甲基异冰片[J]. 供水技术,2016,261:23-25.
      SongShuaiShuai, Wang Xiaobo, Tian Liping, et al.Determination of geosmin anddimethyl isobornol in water by solid-phase extraction gas chromatography-massspectrometry[J]. Water Technology, 2016,261:23-25.
11]马杰,方赤光,李青,等.气相色谱-质谱联用法测定生活饮用水中的土臭素和2-甲基异莰醇[J]. 中国卫生检验杂志,2014,83:50-52.
    MA JieFANG ChiguangLI Qinget al. Determination of geosmin and 2-methylisoborneolin drinking water by gas chromatography-mass spectrometry[J]. Chin J Health LabTec, 2014,83:50-52.
您可能想找: 气质联用(GC-MS) 询底价
symmacros
详细的萃取条件优化。乙酸乙酯作为萃取剂的沸点稍微高一些。
ghyl
原文由 symmacros(jimzhu) 发表:
确实比另外两种高点,不过和目标物的沸点还是有差距,影响不大,而且乙酸乙酯极性大点,和目标物相似
p3292186
Ins_9fa7e52e
正好面临需要监测出厂水二甲基异莰醇的问题,能不购买顶空固相微萃取就能测定对小水厂来说太友好了
