![](https://simg.instrument.com.cn/bbs/images/brow/em09511.gif)
请大虾们帮忙翻译一下以下三句英语,这是一台仪器说明书上的,我有点弄不明白它们的关系
1. YES – All the samples assigned to be analyzed on the concentrator which is no longer coming to a “Purge Ready” condition will be run on the concentrator which is functioning properly. A message will be written to the Error Log.
2. NO – All the samples assigned to be analyzed on the concentrator which is no longer coming to a “Purge Ready” condition will be ignored and not run. A message will be written to the Error Log.
3.The centurion will allow the user options in setting up the sequence table and the vial storage tray based on number of calibrations and concentrators running in the sequence.
